Old 05-19-2015, 12:59 PM   #1
Joe-G
Canada Eh!
Joe-G's Avatar
Drives: '13 FRS
225/45 or 235/40 on 17x7.5
Anyone here have any experience with a 235/40/17 tire on a 17x7.5" wheel?
I've seen plenty of examples where a 235/40 has been stuffed onto a 7.5" wide wheel, but I'm more concerned with performance.
Does the pinched tire negate the added width of a 235? Is the shorter sidewall of a 235/40 better than a 225/45?
Assuming we're comparing the same tire for the purpose of autoslalom... Is it better to just stick to a 225/45?
Looking to upgrade the tires before the next event, not quite sure what size to order.
Joe-G is offline   Reply With Quote
Old 05-19-2015, 01:05 PM   #2
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
There is no blanket answer to this question. Every tire is different. I ran a 225 A5 Hoosier on a 13x6" wheel, but would I run a 225 MPSS on a 17x7" wheel, no. You need to figure out what tire you want to run, then pick a wheel choice. It's not as simple as picking X size tire and fitting a wheel.
The common trend is to stretch a side wall for "faster turn in and more steering response." In many cases doing this couldn't be further from the truth. The A5 I ran was designed to be a cantlevered tire. The sidewalls hung 1/2" over the wheel.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
The Following User Says Thank You to Hyper4mance2k For This Useful Post:
Joe-G (05-19-2015)
Old 05-19-2015, 01:16 PM   #3
Joe-G
Canada Eh!
Joe-G's Avatar
Drives: '13 FRS
I wish I had the luxury of picking a size, tire, then an accommodating wheel. However, my budget is limited and buying new wheels is out of the question.
I'm stuck with a 17x7.5 wheel, and I would like to run either a Dunlop Direzza ZII/ZII* or the Hankook RS3 V2.
Was hoping someone here would have a bit of experience with this similar setup so I can make a better decision.
Old 05-19-2015, 01:27 PM   #4
renfield90
The Stig's German cousin
General internet wisdom says the RS3 doesn't take well to pinching. Go 225 RS3 or 235 star spec.
FYI I run a 245 Rival S on a 7" wheel. The "feel" is a little mushy compared to 225 but otherwise it's making plenty of grip.
The Following 2 Users Say Thank You to renfield90 For This Useful Post:
Hyper4mance2k (05-19-2015), Joe-G (05-19-2015)
Old 05-19-2015, 01:29 PM   #5
Hyper4mance2k
Alexandrino_Auto
Drives: series.Blue
Well there you go, you named a tire. You need to start with tires, then move to wheels. That's simply how it works. Or, you pick whees and try to bandaid the best tire you can.
The taller the sidewall the larger range of wheel widths it will fit. Dunlup recommends the ZIISS 234/45 on a minimum of a 7.5 the 225/45 fits on a 7. The 225 will give you better turn in on a 7.5 at the expense of overall grip. That's a decision you have to make based on how you like the car to drive. Personally I'd go with the 235/45. The same applies to the RS3V2. You can look up the manufacturers recommended wheel widths per tire.
Joe-G (05-19-2015)
Old 05-19-2015, 05:27 PM   #6
Joe-G
Canada Eh!
Joe-G's Avatar
Drives: '13 FRS
Well, it looks like the 235/45 is the way to go. Thanks for all the help!
245/40 on 17x7? 艾洛 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 05-06-2015 03:13 PM
17x7 +25 Or Less Snake Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 02-05-2013 06:46 AM
17x7.0 vs 7.5 G4mb17 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 06-14-2012 01:32 AM
Volk Racing GT-C 17x7 and Gram Lights 57 Optomise 17x7 xravexboix Wheels and Tires 0 05-24-2012 08:04 PM
