Old 05-16-2015, 03:49 PM   #1
Jeff@Racer X Fab
Drives: Subaru BRZ, Toyota MR2 Turbo
Racer X Fabrication, coolant overflow tank
We had a customer contact us recently with a small issue he was having with his coolant overflow. After a few emails he decided to have us move forward with making a custom coolant overflow for his FR-S.
The issue with the OEM coolant tank was the mounting locations. With an aftermarket radiator/fan shroud there was no mounting location for the OEM coolant tank, leaving the customer no option but to zip tie it to the nearest convenient point. He suggested two mounting locations which we used, the first being under the OEM intake box mounting tab, the second is directly behind the OEM coolant cap. These two mounting points allowed us to mount the Racer X coolant overflow tank.
The Racer X coolant overflow tank will work with the OEM radiator and OEM fan shroud. Its design and placement are similar to the OEM overflow tank, the major change is the mounting location. For those individuals that have an aftermarket radiator and a zip tied OEM coolant overflow you might want to consider this product.
As always questions and comments are welcome. Here are a few pictures.
Jeff@Racer X Fab is offline   Reply With Quote
Old 05-16-2015, 04:06 PM   #2
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
What's the passthrough for?
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 05-16-2015, 05:57 PM   #3
Jeff@Racer X Fab
The pass through is to clear the OEM fan shroud. That is where the OEM coolant tank mounts to the fan shroud.
Old 06-08-2015, 10:24 AM   #4
philooo
Drives: 13' Scion FRS Track car
this looks awesome, is that considered a high pressure overflow tank ?
how can you check the coolant level ?
is there a dipstick on the cap ?
philooo is offline   Reply With Quote
Old 06-08-2015, 02:24 PM   #5
Calum
That Guy
Drives: 2013 asphalt FRS MT
The overflow should not be pressurized.
Old 06-08-2015, 02:28 PM   #6
celek
Resident Gear Head
celek's Avatar
Normally your coolant system pressure is limited by the main cap at 18PSi. which releases into the overflow.
You should never need a high pressure tank on your coolant overflow if it blows you have some engine failures causing pressurization of the coolant system.
Coolant level checked by opening the orange cap.
Some aftermarket companies use a clear tube but most of the time they are not suited for coolant and breakdown and fall apart.
celek is offline   Reply With Quote
Toyota filled my coolant overflow with washer fluid Decay107 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 36 08-11-2016 10:18 AM
Racer X Fabrication oil pan design and development! Jeff@Racer X Fab Engine, Exhaust, Transmission 87 06-03-2015 11:10 AM
DIY Changing Cam Plate Racer X fabrication Mr. DIY (Do-It-Yourself) Guides 0 08-06-2014 12:56 AM
Racer X Fabrication heat shield, help us to help you Jeff@Racer X Fab Engine, Exhaust, Transmission 31 07-17-2014 09:20 AM
Racer X Fabrication, New vendor intro Jeff@Racer X Fab Announcements, Contests, Giveaways 0 03-12-2013 11:50 AM
