Drives: Subaru BRZ, Toyota MR2 Turbo
Racer X Fabrication, coolant overflow tank
We had a customer contact us recently with a small issue he was having with his coolant overflow. After a few emails he decided to have us move forward with making a custom coolant overflow for his FR-S.
The issue with the OEM coolant tank was the mounting locations. With an aftermarket radiator/fan shroud there was no mounting location for the OEM coolant tank, leaving the customer no option but to zip tie it to the nearest convenient point. He suggested two mounting locations which we used, the first being under the OEM intake box mounting tab, the second is directly behind the OEM coolant cap. These two mounting points allowed us to mount the Racer X coolant overflow tank. The Racer X coolant overflow tank will work with the OEM radiator and OEM fan shroud. Its design and placement are similar to the OEM overflow tank, the major change is the mounting location. For those individuals that have an aftermarket radiator and a zip tied OEM coolant overflow you might want to consider this product. As always questions and comments are welcome. Here are a few pictures. ![]() ![]() ![]()
#2 |
Alexandrino_Auto
Drives: series.Blue
What's the passthrough for?
The Shadetree Project: I turn wrenches
#3 |
#4 |
Drives: 13' Scion FRS Track car
this looks awesome, is that considered a high pressure overflow tank ?
how can you check the coolant level ? is there a dipstick on the cap ?
2013 Scion Frs Track Car - Sold.
#5 |
That Guy
Drives: 2013 asphalt FRS MT
#6 | |
Resident Gear Head
You should never need a high pressure tank on your coolant overflow if it blows you have some engine failures causing pressurization of the coolant system. Coolant level checked by opening the orange cap. Some aftermarket companies use a clear tube but most of the time they are not suited for coolant and breakdown and fall apart.
Subaru BRZ/FRS Facebook News and Tech Page
My FB Build page CLICK AND LIKE! Twitter and Instagram @misairubrz |
| Toyota filled my coolant overflow with washer fluid | Decay107 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 36 | 08-11-2016 10:18 AM |
| Racer X Fabrication oil pan design and development! | Jeff@Racer X Fab | Engine, Exhaust, Transmission | 87 | 06-03-2015 11:10 AM |
| DIY Changing Cam Plate Racer X fabrication | Mr. | DIY (Do-It-Yourself) Guides | 0 | 08-06-2014 12:56 AM |
| Racer X Fabrication heat shield, help us to help you | Jeff@Racer X Fab | Engine, Exhaust, Transmission | 31 | 07-17-2014 09:20 AM |
| Racer X Fabrication, New vendor intro | Jeff@Racer X Fab | Announcements, Contests, Giveaways | 0 | 03-12-2013 11:50 AM |
