Old 08-06-2014, 12:56 AM   #1
Mr.
Supra Senior Member
Mr.'s Avatar
Drives: AE86 & BRZ
DIY Changing Cam Plate Racer X fabrication
DIY Changing Cam Plate Racer X fabrication.
Well, first you need to know if your cam plate is leaking oil. You can easily check by touching the bottom of your cam plate with your hand. The smell. It will smell like burnt oil. Also, visually checking it you can see the build up at the bottom or on your overpipe.
Installation time: 30mintues to 1 hour.
Tools needed.
A flat head or a pry bar. A towel. 12 mm socket.
Remove OEM bolts. They break off easy.
After they break off I suggest using by hand afterwards. The reason because you do not want the bolts to drop. Your 30 minute job will be an hour.
Pry the cam plate off. Use this point it will be easier.
Clean off the area.
I would suggest using brake cleaner. I sprayed the towel NOT directly on the area.
The new cam racer x fabrication cam plate
Prepare new cam plate. Add some oil around the rings just like a oil filter.
No sealant is required per instruction.
Install time.
Do by hand first.
TQ specification is 12 lbs.
Finished!
More information about the product here: http://racerxfabrication.com/products/fr-s_brz.html
Note: Other aftermarket cam plate install is similar. However, just check if the sealant is required with that brand.
Build Thread
YouTube Channel
IG - Fwankyhong
Subscribe
Mr. is offline   Reply With Quote
Racer X Fabrication oil pan design and development! Jeff@Racer X Fab Engine, Exhaust, Transmission 87 06-03-2015 11:10 AM
Racer X Fabrication cylinder head plate Mr. User/Vendor/Sponsor Reviews, Feedback, Comments 1 08-05-2014 11:02 PM
Racer X Fabrication heat shield, help us to help you Jeff@Racer X Fab Engine, Exhaust, Transmission 31 07-17-2014 09:20 AM
Racer X fabrication rear suspension arms jah29 Brakes, Suspension, Chassis 4 04-06-2014 08:43 PM
Racer X Fabrication, New vendor intro Jeff@Racer X Fab Announcements, Contests, Giveaways 0 03-12-2013 11:50 AM
