| Member's Car Journals Car journals by our members. |
Drives: 2013 BRZ "Sport-Tech"
Lachute Performance BRZ
![]() 2013 Subaru BRZ Features BRZ SPORTECH High-Intensity Discharge (HID) Xenon headlights Voice-activated GPS navigation system Bluetooth® audio streaming and hands-free phone connectivity 8-speaker audio system w/ HD radio & single CD USB port w/ iPod® control Leather-wrapped steering wheel, shift knob & parking brake handle 6-speed manual transmission Limited-slip rear differential Leather/Alcantara® upholstery Keyless Access and Start Dual-zone automatic climate control Heated front seats/heated exterior mirrors Fog lights Trunk spoiler 2013 Subaru BRZ Specs BRZ ENGINE Type: Naturally-aspirated Subaru Boxer 4-cylinder Displacement: 2.0 liters (1995 cc/122 cu. in.) Valvetrain: Dual-overhead camshafts. Four valves per cylinder. Dual Active Valve Control System, Valiable Valve Timing Fuel Delivery: Direct & Port fuel injection Horsepower: 200 t 7,000 rpm Torque: 151 lb-ft @ 6,400 rpm Fuel Requirement: 93-octane premium unleaded Fuel Economy: MT 22/30/25 AT 25/34/28 (city/hwy/combined) BRZ DRIVETRAIN Layout: Front-engine, rear-wheel drive Stability/Traction Control: Vehicle Stability Control (VSC); Traction Control System (TCS) with off switch Transmissions: 6-speed close-ratio manual transmission (standard) or optional 6-speed automatic transmission with manual shift mode and paddle shifters Rear Differential: Torsen limited slip Final drive Ratio: 4.10:1 BRZ STEERING AND SUSPENSION Quick Type: Electric Power Assisted Steering (EPAS) Turning Circle: 35.4 ft. Lock to Lock: 2.48 Front Suspension: Independent MacPherson strut with stabilizer bar Rear Suspension: Independent double wishbone with stabilizer bar BRZ BRAKING Power-assisted 11.6-inch ventilated front/10.5-inch ventilated rear disc brakes Four-channel/four-sensor Anti-lock Braking System (ABS) Electronic Brake-Force Distribution (EBD) Brake Assist Brake Override System BRZ WHEELS AND TIRES 170inch dark gray with machine finish aluminum alloy wheels with 215/45WR17 87W summer performance tires BRZ EXTERIOR DIMENSIONS Overall Length: 166.7 Overall Height: 50.6 Overall Width: 69.9 Wheelbase: 101.2 Track front/rear: 59.8/60.6 Curb Weight: MT - Premium: 2,762 Limited: 2,776 AT - Premium: 2,809 Limited: 2,822 MODIFICATIONS POWER Catback Lachute Performance BRZ Specs *R&D* Frontpipe Lachute Performance BRZ Specs *R&D* Headers Lachute Performance BRZ Specs *R&D* Air Intake Lachute Performance *R&D* HANDLING: Stock (More info coming soon) Wheels & Tires: Stock (More info coming soon) BRAKING: Front: DBA 4000 slotted & Ferodo 2500 Rear: Stock (More info coming soon) ![]() THE AIM OF THE PROJECT: Prepare sporty handling car for track and daily drive. Maintain a reasonable budget. ![]() PICTURES: http://www.facebook.com/media/set/?s...7787995&type=3 http://www.flickr.com/photos/5385126...7630227457436/ ![]() Several products for the BRZ and FR-S will be available soon. Of these many products will be manufactured by Lachute Performance. Regularly check the website or Facebook page for details http://www.lachuteperformance.com/
![]() ![]() EcuTeK tuning available on next Monday !
Boostin'
Drives: FRS-T
So how much is the chip going to be and how much more power are we looking at... I bet odhould also install my cat back and intake should be installed before
AIM4APX
Drives: 2013 WRB BRZ Limited
Very interested in seeing ECU dyno numbers.
[||•]=(86)=[•||]
Drives: 2017 Toyota 86
Interesting... not to far away from my place.
![]() ![]() ![]() Soirée lapping avec l'ASE...premières impressions: La BRZ est très agile, bonne puissance de freinage, un peu plus de sou-virage comparé au FR-S, mais dans l'ensemble pour une voiture de série elle est très étonnante. Le R&D continue...
Drives: 2013 raven black fr-s
I speak french fairly well, but I'm not familiar with the term etonnante. Looking at teh sentace, I imagine it's something negative. Do you mind elaborating some? merci
#9 | |
Étonnante means incredible...surprising at all for a stock setup.
#10 |
thank you, i appreciate it!
#11 |
Pegasus White
Drives: 86
How did the ECUTek tunning go? what results should we expect?
#12 |
more détails coming soon....
#13 |
Boostin'
Drives: FRS-T
Checking this thread again
#14 |
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
| Lachute Performance BRZ | Cotnoir | BRZ First-Gen (2012+) — General Topics | 8 | 08-02-2012 01:06 PM |
| Hello from Accelerated Performance! | Don@Accelerated | Announcements, Contests, Giveaways | 5 | 07-04-2012 08:14 PM |
| TB Performance Products wants YOUR car | TB Performance Products | Scion FR-S / Toyota 86 GT86 General Forum | 0 | 06-13-2012 07:10 PM |
| Nameless Performance is here. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 16 | 06-06-2012 04:32 AM |
