Old 06-15-2012, 06:10 PM   #1
Cotnoir
Cotnoir's Avatar
Drives: 2013 BRZ "Sport-Tech"
Lachute Performance BRZ
2013 Subaru BRZ Features
BRZ SPORTECH
High-Intensity Discharge (HID) Xenon headlights
Voice-activated GPS navigation system
Bluetooth® audio streaming and hands-free phone connectivity
8-speaker audio system w/ HD radio & single CD
USB port w/ iPod® control
Leather-wrapped steering wheel, shift knob & parking brake handle
6-speed manual transmission
Limited-slip rear differential
Leather/Alcantara® upholstery
Keyless Access and Start
Dual-zone automatic climate control
Heated front seats/heated exterior mirrors
Fog lights
Trunk spoiler
2013 Subaru BRZ Specs
BRZ ENGINE
Type: Naturally-aspirated Subaru Boxer 4-cylinder
Displacement: 2.0 liters (1995 cc/122 cu. in.)
Valvetrain: Dual-overhead camshafts. Four valves per cylinder. Dual Active Valve Control System, Valiable Valve Timing
Fuel Delivery: Direct & Port fuel injection
Horsepower: 200 t 7,000 rpm
Torque: 151 lb-ft @ 6,400 rpm
Fuel Requirement: 93-octane premium unleaded
Fuel Economy: MT 22/30/25 AT 25/34/28 (city/hwy/combined)
BRZ DRIVETRAIN
Layout: Front-engine, rear-wheel drive
Stability/Traction Control: Vehicle Stability Control (VSC); Traction Control System (TCS) with off switch
Transmissions: 6-speed close-ratio manual transmission (standard) or optional 6-speed automatic transmission with manual shift mode and paddle shifters
Rear Differential: Torsen limited slip
Final drive Ratio: 4.10:1
BRZ STEERING AND SUSPENSION
Quick Type: Electric Power Assisted Steering (EPAS)
Turning Circle: 35.4 ft.
Lock to Lock: 2.48
Front Suspension: Independent MacPherson strut with stabilizer bar
Rear Suspension: Independent double wishbone with stabilizer bar
BRZ BRAKING
Power-assisted 11.6-inch ventilated front/10.5-inch ventilated rear disc brakes
Four-channel/four-sensor Anti-lock Braking System (ABS)
Electronic Brake-Force Distribution (EBD)
Brake Assist
Brake Override System
BRZ WHEELS AND TIRES
170inch dark gray with machine finish aluminum alloy wheels with 215/45WR17 87W summer performance tires
BRZ EXTERIOR DIMENSIONS
Overall Length: 166.7
Overall Height: 50.6
Overall Width: 69.9
Wheelbase: 101.2
Track front/rear: 59.8/60.6
Curb Weight: MT - Premium: 2,762 Limited: 2,776
AT - Premium: 2,809 Limited: 2,822
MODIFICATIONS
POWER
Catback Lachute Performance BRZ Specs *R&D*
Frontpipe Lachute Performance BRZ Specs *R&D*
Headers Lachute Performance BRZ Specs *R&D*
Air Intake Lachute Performance *R&D*
HANDLING:
Stock (More info coming soon)
Wheels & Tires:
BRAKING:
Front: DBA 4000 slotted & Ferodo 2500
Rear: Stock (More info coming soon)
THE AIM OF THE PROJECT:
Prepare sporty handling car for track and daily drive.
Maintain a reasonable budget.
PICTURES:
http://www.facebook.com/media/set/?s...7787995&type=3
http://www.flickr.com/photos/5385126...7630227457436/
Several products for the BRZ and FR-S will be available soon.
Of these many products will be manufactured by Lachute Performance.
Regularly check the website or Facebook page for details
http://www.lachuteperformance.com/
Cotnoir is offline
Old 06-15-2012, 06:11 PM   #2
Cotnoir
Cotnoir's Avatar
EcuTeK tuning available on next Monday !
Cotnoir is offline
The Following User Says Thank You to Cotnoir For This Useful Post:
illmatic (06-15-2012)
Old 06-15-2012, 10:03 PM   #3
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
So how much is the chip going to be and how much more power are we looking at... I bet odhould also install my cat back and intake should be installed before
Silverdub is offline
Old 06-15-2012, 11:44 PM   #4
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
Very interested in seeing ECU dyno numbers.
Superhatch is offline
The Following User Says Thank You to Superhatch For This Useful Post:
SkAsphalt (08-13-2012)
Old 06-16-2012, 01:26 AM   #5
trueno86power
[||•]=(86)=[•||]
trueno86power's Avatar
Drives: 2017 Toyota 86
Interesting... not to far away from my place.
trueno86power
GR | TOM'S | TRD
2017 Toyota 86
trueno86power is offline
Old 06-19-2012, 10:13 AM   #6
Cotnoir
Cotnoir's Avatar
Cotnoir is offline
MannyO (06-19-2012)
Old 06-19-2012, 11:17 AM   #7
Cotnoir
Cotnoir's Avatar
Soirée lapping avec l'ASE...premières impressions:
La BRZ est très agile, bonne puissance de freinage,
un peu plus de sou-virage comparé au FR-S,
mais dans l'ensemble pour une voiture de série elle est très étonnante.
Le R&D continue...
Cotnoir is offline
Old 06-19-2012, 11:38 AM   #8
bakerr6
Drives: 2013 raven black fr-s
I speak french fairly well, but I'm not familiar with the term etonnante. Looking at teh sentace, I imagine it's something negative. Do you mind elaborating some? merci
bakerr6 is offline
Old 06-19-2012, 11:59 AM   #9
Cotnoir
Cotnoir's Avatar
sorry...
Étonnante means incredible...surprising at all for a stock setup.
Cotnoir is offline
Old 06-19-2012, 12:04 PM   #10
bakerr6
thank you, i appreciate it!
bakerr6 is offline
Old 06-19-2012, 06:51 PM   #11
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
How did the ECUTek tunning go? what results should we expect?
DriftEightSix is offline
Old 06-20-2012, 09:38 AM   #12
Cotnoir
Cotnoir's Avatar
more détails coming soon....
Cotnoir is offline
Old 06-20-2012, 06:31 PM   #13
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Checking this thread again
Old 06-21-2012, 02:41 PM   #14
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
Any updates??
uspspro is offline
Lachute Performance BRZ Cotnoir BRZ First-Gen (2012+) — General Topics 8 08-02-2012 02:06 PM
Hello from Accelerated Performance! Don@Accelerated Announcements, Contests, Giveaways 5 07-04-2012 09:14 PM
TB Performance Products wants YOUR car TB Performance Products Scion FR-S / Toyota 86 GT86 General Forum 0 06-13-2012 08:10 PM
Nameless Performance is here. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 16 06-06-2012 05:32 AM
