Old 06-07-2013, 03:21 PM   #1
taimysho0
Drives: frs
Modify Preload on Brand new Coilvers or Leav Alone? Measurement to get 1 finger Gap?
i have my new coils (stance) coming in tomorrow and before install, i was planning to leave the preload alone and not modify it. Do you guys normally modify this or leave it as is? I feel like if I touch it, i might mess up haha. Im planning to have a 1 finger gap between the tire and fender, any suggested measurements on the gap between the height adjustment perch and the preload lock perch to achieve this?
taimysho0 is offline   Reply With Quote
Old 06-07-2013, 06:22 PM   #2
Jarumie42172
Drives: 1992 BMW E36 325i, 2013 Scion Frs
Well I got the bc set and I never adjusted the preload. But I'm thinking the preload should already be set out of the box for stance as well
Jarumie42172 is offline   Reply With Quote
Old 06-07-2013, 07:49 PM   #3
taimysho0
Drives: frs
ok thats what i thought, i was just looking at the DIY guide for coilovers on here and the guy had to set the preload as one of the steps
Old 06-07-2013, 08:11 PM   #4
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
BC coilovers definitely do not come pre-set, and I wouldn't think the Stance do either. It is always recommended to check your preload before installing. It is very simple to do with coilovers new and off the car.
No Limit Motorsport is offline   Reply With Quote
Old 06-07-2013, 08:29 PM   #5
g0lden
Drives: 2013 Scion FR-S Argento
I just installed my BC Extreme Low coils, and the instructions from BC say not to mess with pre-load as they are set from factory. You should only have to adjust the ride height adjuster perch.
g0lden is offline   Reply With Quote
Old 06-07-2013, 10:40 PM   #6
Jarumie42172
My bc's came with a pre set preload
Do you modify your car just to be different? #87 Off-Topic Lounge [WARNING: NO POLITICS] 31 02-08-2013 10:14 PM
Need help with Stock height measurement D1cker Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 08-03-2012 03:30 AM
You don't break track records by settling! Custom Valved BC Coilvers and Carbotech XP Element Tuning Brakes, Suspension, Chassis 24 07-23-2012 09:35 PM
trunk measurement question sieeegel BRZ First-Gen (2012+) — General Topics 9 05-05-2012 12:27 PM
