Old 05-12-2015, 05:56 PM   #1
fasteddy
Spare wheel/tire for big brake kit?
Any suggestions on this that will fit in the same spot in the trunk? I have the AP racing factory brake kit which fits the factory 17' wheels. The spare is not even close though.
Thanks.
Pat
fasteddy is offline   Reply With Quote
Old 05-12-2015, 06:37 PM   #2
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
I don't have one. If I do need to carry one, I bring 1x stock wheel + spacers since I have ARP studs.
-alex
Old 05-12-2015, 06:43 PM   #3
mav1178
mav1178's Avatar
You can also look for old 5-100 bolt pattern Subaru w/ large(r) calipers, those may have spares that will work.
Edit: 2004 WRX STi was the only STi w/ 5-100 bolt pattern.
-alex
Old 05-12-2015, 07:00 PM   #4
cnk
Drives: '13 DGM BRZ Limited
You could always do the "musical wheels dance" in a pinch. Front flat. . jack up rear, put donut on rear, take rear and put it on the front.
cnk is offline   Reply With Quote
Old 05-12-2015, 07:04 PM   #5
cjd
cjd's Avatar
Drives: 2017 BRZ
Donut on the back isn't going to be good for much distance.
I'm happy the spare fits the Sprint kit, don't envy trying to find an option. Studs and a spacer may be the best all around option.
Old 05-12-2015, 07:39 PM   #6
Vampyre
Vampyre's Avatar
Drives: 2014 FR-S Asphalt
Why? The spare isn't rated for distance front or rear.
Vampyre is offline   Reply With Quote
Old 05-12-2015, 07:41 PM   #7
mav1178
mav1178's Avatar
Donut on rear is specifically mentioned not to be used, as it puts excessive wear on your diff (even for a short distance).
-alex
The Following User Says Thank You to mav1178 For This Useful Post:
Sleepless (05-12-2015)
Old 05-12-2015, 08:43 PM   #8
cnk
Nope. . .that's why I said in a pinch. I put my donut on the rear for 1 mile to get home once. Didn't want to do it, but it was safer than trying to swap wheels around where I got the flat and pulled over. Trying to change a tire with 18 wheelers and cars passing by 2' away from you is not what I call fun.
Old 05-12-2015, 08:57 PM   #9
Donut in the rear will really, really stress your differential.
Old 05-13-2015, 12:49 AM   #10
churchx
churchx's Avatar
Drives: 2014 GT86
Mike: isn't extended diff wear only when wheels are of different outer diameter? And shouldn't right sized donut with right sized tire fix that enough for reasonably short distances?
Old 05-13-2015, 02:34 AM   #11
It's 0.2" diameter undersized. Is it a lot? No. But, it's enough to make your diff work hard. You'll also get some very, VERY odd cornering behavior with a (torsen) LSD in the rear.
Anyone who's upsized to a 225/45/17 or 255/40/17, or most 18" wheels will likely have VSA kicking in constantly, even in a straight line, if you're going more than a crawl.
Old 05-13-2015, 03:03 AM   #12
churchx
churchx's Avatar
Drives: 2014 GT86
But normal 17" donut used together with oem rims & stock primacies? Or even if with other type of rims/tyres but of stock 17x7 & 215/45/17 sizes? I never intended to go for wide rubber while on NA anyway .. donut is there just as more usable fix in a bind then stock tire fix kit to go 25-50km with easy on throttle at or below legal speeds till closest tire shop.
Well, if it is that bad even if with stock wheels for diff, then of course i can replace with front one. Just more time/work, hopefully not in bad weather conditions . I guess chosen 17" will be easier to fit on front then 16" even if some BBKs are installed ..
Old 05-13-2015, 10:02 AM   #13
fasteddy
-alex
I'll try to get one of these, that should work, Thanks!
That fits with the sprint kit? are you sure? I just can't imagine how as you need to run a 10mm spacer to fit a stock wheel.
Pat
Old 05-13-2015, 12:05 PM   #14
wparsons
wparsons's Avatar
It's the offset and spoke clearance that makes you need a spacer, not the diameter of the barrel. If you look at the spare, it's a very different offset than the stock wheels.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
CSG Mike (05-13-2015)
Will u remove the spare tire? Bahraini86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 133 05-06-2019 11:18 AM
Spare tire ??? Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 09-28-2014 06:46 PM
Spare tire question Raven23 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 09-28-2013 10:23 AM
Volume of spare tire well? djliquidsteele Electronics | Audio | NAV | Infotainment 1 06-18-2012 12:22 AM
Would you want a spare tire in your FR-S? iff2mastamatt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 120 01-12-2012 10:46 PM
