Old 09-26-2013, 03:43 AM   #1
Raven23
Spare tire question
This might be a noob question, but I'll ask anyways.
If I get aftermarket wheels (18s) will I have a problem if I blow a tire out? Can I put on the spare tire and still drive it? Im assuming the spare is 17s cause of OEM wheels?
THanks!
Raven23 is offline   Reply With Quote
Old 09-26-2013, 05:13 AM   #2
ZionsWrath
Thanks
ZionsWrath's Avatar
As long as you keep the total diameter close with a lower profile tire on 18" wheel it will be no problem.
Old 09-26-2013, 06:32 AM   #3
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
that or save 2 oem wheels to run on front or rear just incase.
Build Thread
Instagram
Old 09-26-2013, 08:36 AM   #4
ZionsWrath
Thanks
ZionsWrath's Avatar
Unless you are carrying those in your trunk and/or you have a really obscure tire size and model, that is a waste. Shouldn't take more than a couple days maximum to get a new spare tire if ordered new online. Our cars run a common stock size which should mean they have a common +1 (18") size as well, and any chain tire store should stock it or be able to order one easily.
Old 09-26-2013, 08:52 AM   #5
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
THanks!
the spare is smaller, than 17", it is a "half sized" spare.
but
that's okay, because it's for emergencies and you can put it on and drive the car fine.
keep in mind however,
if you have to change a wheel in the rear, you have to take off a healthy tire from the front, put that on the rear, and the spare on the front.
reason for this is because our cars have LSD... and also because the rear are the drivewheels, and having your drivewheels of different diamaters would cause funky shit.
furthermore, keep in mind that if you're slammed that a spare tire might leave you scraping ground... so if you are lowered and plan on using a spare then make sure you could actually mount it and drive.
Old 09-26-2013, 09:05 AM   #6
ZionsWrath
Thanks
ZionsWrath's Avatar
but
Half sized refers to width, not diameter. There should be no problems with ground clearance.
As for mounting it on a non drive wheel, he should be driving VERY conservatively with a spare mounted and if that is the case it shouldn't matter much. But yes ideally mount to non drive wheel and drive VERY SLOW; at or under the speed limit and baby the throttle if its on the drive wheel.
Old 09-28-2013, 10:23 AM   #7
SuperKazRacing
Drives: 2013 RED FR-S
I thought that was what AAA is for?
Also SCION has there own Roadside assistance program included {it was for me}:happy0180:
SuperKazRacing is offline   Reply With Quote
Is anyone making a spare tire sub box? djliquidsteele Electronics | Audio | NAV | Infotainment 4 08-07-2013 10:39 PM
Spare tire delete? photomike Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 45 03-12-2013 12:51 PM
FR-S meets spare tire at 70 mph dulaman Scion FR-S / Toyota 86 GT86 General Forum 10 11-24-2012 02:15 PM
Volume of spare tire well? djliquidsteele Electronics | Audio | NAV | Infotainment 1 06-18-2012 12:22 AM
Would you want a spare tire in your FR-S? iff2mastamatt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 120 01-12-2012 10:46 PM
