BoostedBRZ
Drives: Turbo BRZ
Dented fuel injector?
The Mechanic
Drives: Civic Turbo,FR-S
Port or di?
Drives: SWP BRZ
I would get replacement. dont want to risk anything even its 1% there
Drives: 86
clean it with injector cleaner
Drives: white-out FR-S
Never pulled this part out before. Where is it located?
BoostedBRZ
Drives: Turbo BRZ
it's a port injector. I've installed it anyways. I emailed DW about it and they said it should be fine because if it was like that already that means it was tested with the dents and passed. They said it was just the the metal casing around has no function but to protect it. The actual spray pattern wouldn't be affected. So we're good! I installed it and the car fired right up, no stumbles, nothing
Now I can enjoy my e85 and moto east's flex fuel kit
#7 | |
Drives: 2013 BRZ Limited M/T
Good cause mine arrived and I have one just like it...
On a side note. I too have the DW's. Do you have any install reference material you are using? Quote:
#8 | |
BoostedBRZ
Drives: Turbo BRZ
| FRS-BRZ Port Fuel Injector (interesting) | Element Tuning | Engine, Exhaust, Transmission | 50 | 04-21-2016 04:26 PM |
| Fuel injector install question | nlowell | Engine, Exhaust, Transmission | 1 | 03-21-2015 11:12 PM |
| after market fuel injector upgrade | BRZ888 | Forced Induction | 4 | 02-24-2015 06:38 PM |
| Fuel injector cover | Notorious RBG | Engine, Exhaust, Transmission | 1 | 01-29-2015 08:14 PM |
| Fuel Injector Cleaner | Purdue FR-S | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-18-2013 06:54 AM |
