Old 08-27-2014, 11:09 PM   #1
nlowell
nlowell's Avatar
Drives: 2013 Scion FRS
Fuel injector install question
Had some new Grams 550cc injectors installed today at infamous. They said that because the injectors are taller than OEM, it required modification of the blast shield/bracket surrounding the fuel rail. They modified the passenger side but not the drivers side.
Has anyone else who installed grams injectors (or other taller injectors) experienced this? If so, what was your solution?
Thanks in advance!
nlowell is offline   Reply With Quote
Old 03-21-2015, 11:12 PM   #2
DAN_BRZ
DAN_BRZ's Avatar
Drives: 2013 WRB BRZ Sport Tech
Thanks in advance!
Do you know what exactly had to be modified? Did the shield just need to be notched around the harness? Can anyone comment on this.... I'll be installing grams injectors in a few weeks and want to be ready...
DAN_BRZ is offline   Reply With Quote
FRS-BRZ Port Fuel Injector (interesting) Element Tuning Engine, Exhaust, Transmission 50 04-21-2016 04:26 PM
Stock fuel injector o-ring material? CaptainSlow Engine, Exhaust, Transmission 0 05-21-2014 10:48 AM
FS: Slightly Used BRZ/FR-S Fuel Injector Clinic (FIC) 540cc injectors Area86 Engine, Exhaust, Bolt-Ons 6 01-23-2014 04:21 PM
Fuel Injector Cleaner Purdue FR-S Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-18-2013 06:54 AM
Dynosty FR-S/BRZ Fuel System Upgrades! Injector Dynamics ID850s! Dustin@Dynosty Engine, Exhaust, Bolt-Ons 0 08-21-2012 05:03 PM
