Old 05-04-2015, 01:50 PM   #1
ZachTTerrell
Drives: Black 2013 Scion FR-S
Aftermarket Rims!
Hey guys! I'm a noob to the FR-S world. Just got a 2013, and looking at aftermarket rims. Would I have to get new tires to fit these? And also for those of you that have black rims, which kind did you get and are you happy with the way they look? Thanks!
ZachTTerrell is offline   Reply With Quote
Old 05-04-2015, 01:54 PM   #2
adamg
Drives: brz
adamg is offline   Reply With Quote
The Following 7 Users Say Thank You to adamg For This Useful Post:
boucher (05-04-2015), brandonblt2 (05-04-2015), chas3wba0 (05-04-2015), golfyankee2121 (05-04-2015), kch (05-04-2015), nivek111070 (05-04-2015), P86RAVES (05-04-2015)
Old 05-04-2015, 02:11 PM   #3
CrazyWookiee
Drives: Whiteout FR-S
It depends on your new sizing. For tires it depends on diamater of your rim and width of your rim.
If you had a 17" factory tire, it won't fit on any other size rim in diameter.
Width however, can be played with. You can "stretch a tire" to a certain amount of rim width, but its up to your discretion and safety.
Our factory tire is a 17" rim, with a 215mm wide tire.
If you get a 16, 18 or any other diameter rim. It's not gonna fit.
If you stick with a 17" rim, then depending on how wide you go, it may not fit. Our factory rim is 7" wide. You could stretch the 215 onto an 8" wide, but past that it's again up to your discretion.
I can't help you with Rim choices, because its a personal preference.
"I'm the real Peter Lau" - Peter Lau
CrazyWookiee is offline   Reply With Quote
The Following 2 Users Say Thank You to CrazyWookiee For This Useful Post:
BRZZZZZZZZZZ (05-05-2015), P86RAVES (05-04-2015)
Old 05-04-2015, 02:25 PM   #4
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
buy 22's
The Following 3 Users Say Thank You to continuecrushing For This Useful Post:
boucher (05-04-2015), golfyankee2121 (05-04-2015), kch (05-04-2015)
Old 05-04-2015, 03:38 PM   #5
ryoma
ryoma's Avatar
slap on some monster truck rims and tires with a lift kit.
seriously though, stick with a 17" rim since 18" are usually a bit heavier. if you're into the look of 18", then go with those but I would stick with 17" for performance-wise. you can save a couple of lbs. also look for a light weight wheel, somewhere around 16 lbs. my RPF1's are 15 lbs which is extremely light.
the trickier thing is offset. it depends on what you like. our stock rims are +48 offset. some people like +35 offset, which lets the front stick out past the fender a little bit. if you lower your car, you might need to either roll the fenders or get more negative camber to make sure you don't rub your fender.
width, it's up to you on how wide you go. you can stick with the stock x7, or go x8 or x9. 17x9 would barely fit with the stock suspension. tbh, I don't see any benefits of 17x9 unless you have plans to make this a high horsepower car, or you like the meaty look.
you can usually get away with 225 wide tires with x7 (tight fit), x8, or x9.
I'm currently running 17x8 +45 on 235/45/17. the tire choice probably isn't the best, but it was the cheapest for me. 225 would probably work better on x8.
remember, our stock wheels are 17x7 +48 and 5x100 pattern. you'll also need hub centric rings for aftermarket wheels. our hub bore is 56.1mm. you'll need to figure out the bore of your aftermarket rims. and don't use the stock lug nuts with aftermarket wheels.
The Following User Says Thank You to ryoma For This Useful Post:
Old 05-04-2015, 04:10 PM   #6
ZachTTerrell
Thanks guys. I didn't really understand the measures of the stock wheels. All I kee was that they're 17". I'm fine with sticking with that diameter but don't know if I'm going to try to match the width. I guess my problem now is making sure that the bolt pattern is right and all that
Old 05-04-2015, 04:11 PM   #7
ZachTTerrell
http://www.carid.com/konig-wheels/co...-43935372.html would these be ok?
Old 05-04-2015, 04:15 PM   #8
adamg
Drives: brz
ugly
Old 05-04-2015, 04:25 PM   #9
gramicci101
Off Topic
Looks are up to you. It's your car, after all.
Konig Controls come in 17x7 +45, so those will fit just fine. I couldn't find the size of their center bore, but it's probably either 56.1 or 73. You could use the OEM tire size on them, or step up to 225/45-17.
They also come in 18x8 +45, which would work too. I would run a 225/40-18 tire on those.
The Following User Says Thank You to gramicci101 For This Useful Post:
Old 05-04-2015, 04:26 PM   #10
ryoma
ryoma's Avatar
keep in mind that you get what you pay for.
Old 05-04-2015, 04:49 PM   #11
GA_Dave
Drives: 2014 Dark Gray Metallic BRZ Limited
Tire choice is also going to depend on what you plan to do with the car. If you want to drift, you may want to look at tires widths less than the wheel width. This will cause the stretch mentioned earlier in the thread. Stretch will make it easier to break the rear end loose and get some better slides.
If you plan on drag racing or auto-x'ing, you will want more grip than the stock tires can offer. Additionally, if you plan to mod the car to make more power (E85, turbo, SC, power blocks, etc.), you will also need some wider tires to get all that power to the ground. In this case, you will probably want to go with a wider tire and wheel with minimal stretch or tuck. Some common combinations on here are 255's on a 8.5" wheel or 245/235's on a 8" wheel. Note that depending on what you want to do with the suspension and brakes, you may need to run a lower offset or spacers to allow your wheel spokes to clear your brake calipers and struts. These can cause some aesthetic issues such as poke.
Lastly, consider the sidewall height when shopping. If you get a larger or smaller wheel, but the same sidewall height, your circumference will change, causing your speedometer to read low or high respectively.
Hope this helps!
GA_Dave is offline   Reply With Quote
The Following User Says Thank You to GA_Dave For This Useful Post:
Old 05-04-2015, 05:00 PM   #12
golfyankee2121
Always Moving Forward
golfyankee2121's Avatar
Drives: 2013 Argento Scion FR-S
There are so many variables man. First, need to learn to search the forums. There are literally thousands upon thousands of different wheel/tire size/color combinations. Look through the Wheel directory (the link below) and figure out what you like. If you're on stock height, the widest wheel you can go is 9 inches or so, depending on the offset of the wheel. Currently, I am on XXR530 18x8.75" +33 wheels with Hankook Ventus V12 K120 245/35/ZR18" tires and love the setup. I attached a few pictures so you can get an idea. Also, you're looking for wheels that have a 5x100 hub bore, and most aftermarket wheels will require hub-centric rings.
Hope this helps.
J.B.
Start here----> http://www.ft86club.com/forums/showthread.php?t=7535
golfyankee2121 is offline   Reply With Quote
The Following User Says Thank You to golfyankee2121 For This Useful Post:
Old 05-04-2015, 07:41 PM   #13
ZachTTerrell
Thanks for the help!
Old 05-04-2015, 07:59 PM   #14
boucher
Leaux Down Krewe
boucher's Avatar
Drives: 2014 SSM Limited
The higher the offset you can find, the better.
Follow me on IG: @rougarou86
boucher is offline   Reply With Quote
Using OEM Mic for Aftermarket Radio AND/OR Replacing OEM Mic with Aftermarket Mic ecko04 Electronics | Audio | NAV | Infotainment 10 05-05-2018 03:47 PM
WTB 17"+ Aftermarket Rims IIDutch Canada Classifieds 2 10-25-2014 02:59 PM
NEED HELP!! TPMS light on. with TPMS installed on aftermarket rims+tires Figo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 09-23-2013 08:11 AM
Eibach Sportlines Aftermarket rims Question. HATED1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 03-22-2013 07:08 PM
SCION FRS/BRZ AFTERMARKET RIMS AND TIRES FOR LOCAL PICKUP $800 FRS-Jay Great Lakes 2 02-20-2013 07:06 PM
