Old 04-25-2015, 03:24 PM   #1
Aozora.BRZ
Aozora.BRZ's Avatar
Drives: '15 WRB Series.Blue
Question What is this disconnected connector by the ECU?
Just noticed this unplugged 4 pin grey connector at the ECU harness and wondered what it is. Searched but couldn't find discussions about it.
Any interesting JDM functionality that may be enabled from it?
Looked at the electronics diagram but still couldn't pinpoint this one.
http://www.ft86club.com/files/BRZwiringi.pdf
Image:
Aozora.BRZ is offline   Reply With Quote
Old 04-25-2015, 04:19 PM   #2
KevinK121
Miata traitor
KevinK121's Avatar
Drives: 2002 Miata SE
Interesting
KevinK121 is offline   Reply With Quote
Old 04-25-2015, 04:22 PM   #3
gramicci101
Off Topic
That actually controls the seat massagers. It's an option on JDM models, but I've heard it's near impossible to get outside of Japan. Something about export duties, I don't know.
The Following User Says Thank You to gramicci101 For This Useful Post:
Ultramaroon (04-25-2015)
Old 04-25-2015, 04:29 PM   #4
mikeTee
Yup.
mikeTee's Avatar
Drives: MT Subaru BRZ '13
mikeTee is offline   Reply With Quote
The Following User Says Thank You to mikeTee For This Useful Post:
Old 04-25-2015, 04:38 PM   #5
mikeTee
Yup.
mikeTee's Avatar
Jokes aside, on the FR-S with an addition of a harness, it is used for the USDM fog light kit.
Old 04-25-2015, 05:14 PM   #6
Aozora.BRZ
Aozora.BRZ's Avatar
That looks like it. Thanks. Our fog light switch is on the turn signal arm for the Limited cars.
I wonder up to what point the unused wires actually run to the front of the car to use with a switch for controlling something else. I may need to review that wiring manual again knowing this.
Old 04-25-2015, 05:33 PM   #7
mikeTee
Yup.
mikeTee's Avatar
I actually have the FR-S fog light switch + harness and a BRZ Limited so I can try plugging in the switch and seeing what happens - hopefully my car doesn't explode.
Old 04-25-2015, 11:39 PM   #8
Ashikabi
Ashikabi's Avatar
Controls the AWD, you should plug that in right away.
Jkjk I have no idea what that is
Old 05-04-2015, 03:52 PM   #9
mikeTee
Yup.
mikeTee's Avatar
Works as an auxiliary fog switch in the limited BRZ, notice how the fog on the stalk is in the off position and the fog light indicator is illuminated in the cluster. When both are on, nothing special happens.
Old 05-04-2015, 04:19 PM   #10
Ashikabi
Ashikabi's Avatar
Probably for your turbo button
ecu harness connector
ECM Pin Connector simpleisbest Software Tuning 19 01-18-2015 02:13 AM
What's this connector ? mashal Electronics | Audio | NAV | Infotainment 5 12-10-2013 01:13 AM
battery disconnected/reconnected -- runs like shtako jonbonazza Issues | Warranty | Recalls / TSB 2 06-19-2013 10:56 AM
Help, what connector is this? Hayashi Cosmetic Modification (Interior/Exterior/Lighting) 0 02-26-2013 01:39 AM
