Old 04-23-2015, 06:34 PM   #1
Flat_4_Life
Flat_4_Life's Avatar
Drives: 2015 SBD Turbo Halo FRS
Exclamation RomRaider NOOB NEEDS HELP!
So I'm trying to learn how to use romraider and I'm sorrda stuck. I'm trying to upload the stuff I need to upload to rom raider. First I clicked ECU Definition manger and I choose the one I downloaded (ZA1JD00C). I clicked apply nothing happens so I hit save, nothing happens. I get frustrated looking for some to click that will do something so I click open image and find bin. I think?(Stg 1 D00C.bin). Then it opens what I want to see but I can't seem to edit anything such as ignition timing advance, base timing B. I can see the chart but can't edit. What am I doing wrong?
Flat_4_Life is offline   Reply With Quote
Old 04-23-2015, 06:55 PM   #2
Bader
Drives: 2013 WRB BRZ
Open your definition manager and make sure the tune xml file is listed there. That will allow you to load it up. If you're using OFT tunes then make sure to use the definition which comes packed with the OFT tunes.
As for changing values in tables. You can copy entire tables from one tune and paste them in the corresponding table in another tune or you can select the fields you want to change and manually enter the values. (Look up top, there should be an empty box next to the "set" button).
Just don't change anything if you don't know what it's supposed to do. Good luck and have fun.
Bader is offline   Reply With Quote
RomRaider itsjustdavep Software Tuning 34 03-18-2017 03:48 AM
First romraider defs are up jamesm Software Tuning 95 01-13-2015 05:29 AM
need some help with romraider logger toyotaAlex Software Tuning 2 07-06-2014 07:07 PM
romraider/OFTquestion/problem? bkblitzed Software Tuning 10 06-08-2014 02:30 AM
RomRaider XML definitions. wparsons Software Tuning 9 03-25-2014 11:24 AM
