It's the Mad Cow
ECUTek Cable has OBD Error when Attempting to Log
So I can load a tune, the interface shows that it see's everything but as soon as I hit Map Access it errors saying it did not receive and ODB Response? Yet if I unplug it and plug it back in it still say's it see's everything it just will not log.
I was going to call ECUTek but they are overseas so that ended that. Has anyone else had this issue, it's rather frustrating that I cannot log to send information to my tuner but I can load his tunes....
05 GTO 408 Stroker \ 13 FRS 210 Twin Screw Supercharger on E85 \ 14 F-150 5.0L |
Drives: UK GT86
You get something similar of the USB is loose or the OBD connector is loose. That's my bet.
Are you using the time they sent you to log?
.: Stealth 86 :.
It's the Mad Cow
The time?
I played with it more, uninstalled and reinstalled the drivers everything and the computer see's the cable no issues it just has issues keeping the connection to the car. I tried messing with the car ODBII Connector end no luck then messing with the cable I got it to work for a short time then stop, wiggled it again and it worked again for a few minutes then stopped. Thankfully the last time I was able to get the data I wanted to show the tuner logged before it errored again. I think the cable has a short in it but without another cable to test with I am not sure.
Drives: 86 GTS White
Try pulling the OBD2 connector towards you and holding it there. Does it log for longer?
I have to wrap the cable around the gear stick to hold it in the pulled back position since the port is dodgy. I suspect a pin has been pushed back, but it's so damn awkward to work in that space that I haven't been bothered to fix it. |
Drives: 2013 FRS
Sorry to resurrect, but I'm having the exact same issue. Were you ever able to resolve it or figure out what the cause was?
Drives: Toyota GT86
The early FRS have a weak ODB connector, the best thing to do is to buy a extension cable and connect the ECUtek (or OFT, Tactrix) cable with that. It's possible you need to bend some pins to make a good connection.
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners |
| WTB: Ecutek Cable | SunkenFRS | Engine, Exhaust, Bolt-Ons | 0 | 10-18-2014 04:04 PM |
| wtb ecutek cable | bakerr6 | Want-To-Buy Requests | 0 | 10-18-2014 02:30 AM |
| Wtb ecutek cable! | ThisGuy919 | Want-To-Buy Requests | 5 | 08-25-2014 04:35 AM |
| ECUtek reflashing error | Kwaziekeller | Software Tuning | 4 | 08-04-2014 11:36 PM |
| ECUtek error 37 | NickFRS | Software Tuning | 5 | 06-29-2014 04:14 PM |
