Old 04-14-2015, 11:44 PM   #1
Naeblis
Drives: Subaru BRZ
How to wire int the reverse light?
Does anyone know how to wire into the reverse light power on the BRZ? I bought a [ame="http://smile.amazon.com/Wireless-Transmitter-Receiver-Vehicle-Backup/dp/B008Z9E4DW/ref=cm_cd_al_qh_dp_t"]wireless transmitter/receiver[/ame] to see how well it would work instead of running a cable through the car for the backup camera. But I'm not sure how to tie the transmitter into the reverse light power so it'll turn on when it's in reverse
Naeblis is offline   Reply With Quote
Old 04-16-2015, 07:08 PM   #2
RickyBobby
Drives: 2013 Firestorm FR-S AT
Will this even work if you wire it into the reverse light? Read the section Camera Detect: http://ae64.com/Rear-camera-16p-operation.htm
It's not difficult to run the camera wire to the HU. See my post here: http://www.ft86club.com/forums/showp...5&postcount=20
If you purchase a camera that will run on 6V, like a genuine Rydeen, then all you would need is SVXdc's Bypass wire harness. http://ae64.com/Rear-camera-16-pin.htm You do not need a reverse trigger wire with a BRZ.
RickyBobby is offline   Reply With Quote
backup camera, reverse light
How to wire a fog light switch to Diode Dynamics fog light kit *SOLVED tiz22 Cosmetic Modification (Interior/Exterior/Lighting) 6 06-04-2014 01:16 AM
Transmission Reverse wire sufu05 Engine, Exhaust, Transmission 2 12-11-2013 11:26 PM
For Sale: Smoked/Red/Clear Reverse Light + Brake Light Bars Brand New! Vicious LED Exterior Parts (Aero, Lighting, Etc.) 9 08-25-2013 07:26 PM
Reverse light wire location? derka-derka AUSTRALIA 1 05-29-2013 09:19 AM
Reverse Wire Tap wire Location? Norkoastal Electronics | Audio | NAV | Infotainment 2 10-19-2012 10:22 AM
