Old 04-14-2015, 09:46 AM   #1
Timmy_Jones
Spun
Drives: 23' Supra
Anyone Running 17" Front and 18" Rear?
Was thinking about going 17 front and 18 rear with the Rota RT5.
Anyone running a similar setup? The thought spawned when a vendor I was working with was out of the 18x8.5, and I didnt want to run 18x9.5 front.
Timmy_Jones is offline   Reply With Quote
Old 04-14-2015, 09:50 AM   #2
Timmy_Jones
Spun
Drives: 23' Supra
Looks decent here:
Old 04-14-2015, 01:10 PM   #3
Vampyre
Vampyre's Avatar
Drives: 2014 FR-S Asphalt
I was actually thinking of doing the same. 17x8.25 front and 18x8.75 rear with 235/45r17 and 255/35r18 tires or something similar.
Vampyre is offline   Reply With Quote
Old 04-14-2015, 02:47 PM   #4
Timmy_Jones
Spun
Drives: 23' Supra
Yup - would love to hear what others think.
Old 04-17-2015, 03:57 PM   #5
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
Almost everyone I've talked to who has staggered wheels regrets it. Better to keep the width square, this car was not designed for staggered setups. Yes it is physically possible and has been done, but it will have a negative effect on your handling.
As far as diameter goes for aesthetics, I don't know how a 17"/18" combo would work with the same width, that may be more the avenue you want to take.
DoomsdayJesus is offline   Reply With Quote
Old 04-18-2015, 02:30 AM   #6
mike_frs
mike_frs's Avatar
Drives: 2015 Subaru BRZ Limited
So is it safe to say staggered setups for our cars is just for looks?
mike_frs is offline   Reply With Quote
Old 04-19-2015, 08:57 AM   #7
J-W
J-W's Avatar
Drives: '13 Subaru BRZ Limited
I wouldn't say just for looks. If the setup is right, it could be beneficial on a drag strip as you could achieve more grip in the rear and steering isn't as crucial.
J-W is offline   Reply With Quote
Old 04-19-2015, 02:03 PM   #8
Poodles
Drives: 2015 Series.Blue
Usually it's done the opposite way. Larger up front to clear the brakes, bigger in back for a better drag tire.
Doing it the opposite way might be ok for drift though as the smaller sidewall might help in the rear.
If you do it with different overall diameters, the ABS system is going to freak, so it might look silly with more sidewall in front than rear.
To those running 18x9.5" up front..question OICU812 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 68 11-02-2015 10:19 AM
"Clicking" or "knocking" caused by rear seat pull down lever. husker741 Issues | Warranty | Recalls / TSB 6 11-27-2013 02:30 PM
"LED Strip Daytime Running Lights and Valenti Tails --- Shipped Anywhere!!" F-T Exterior Parts - Lighting 187 05-15-2013 01:07 AM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
18" front and 19" rear anyone!? Zardoman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 10-07-2012 09:34 PM
