Old 04-09-2015, 08:19 PM   #1
carma143
carma143's Avatar
Drives: Toyota Highlander; Subaru BRZ (SWP)
Torque OBDII Test Results
Last week I bought and used this product here: [ame="http://www.amazon.com/gp/product/B005NLQAHS/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1"]Amazon.com: BAFX Products - Bluetooth OBD2 scan tool - For check engine light & diagnostics - Android ONLY: Automotive[/ame]
I connected it to my Limited BRZ (2013) and several tests received a 'FAIL'. I am not confident that I know how to interpret all this. Any help is appreciated.
MID:$0e TID:$0c
Misfire counts for last/current driving cycles(calculated) - O2 Bank 4 Sensor 2
Max: 53,336 Min: 22,745
Test result value: 3
FAIL
MID:$1f TID:$fe
Max: 53,248 Min: 27,977
Test result value: 323
FAIL
MID:$21 TID:$89
- Catalyst Monitor Bank 1
Test incomplete or dependant test failed
MID:$2e TID:$0c
Max: 53,248 Min: 27,961
FAIL
MID:$0e TID:$0c
FAIL
MID:$1f TID:$fe
FAIL
MID:$21 TID:$89
MID:$2e TID:$0c
FAIL
MID:$3d TID:$cc
- EVAP Monitor (0.020")
MID:$3e TID:$0c
Misfire counts for last/current driving cycles(calculated) - Purge Flow Monitor
Max: 53,332 Min: 26,841
FAIL
MID:$3f TID:$fe
Max: 53,248 Min: 23,881
FAIL
carma143 is offline   Reply With Quote
Old 04-10-2015, 09:14 PM   #2
FirestormFRS
Seeing as your results are all 3 or 323 I think your reader or your OBD2 port or both aren't communicating very well. Don't worry about it if the car is running ok and there are no CEL's on.
FirestormFRS is offline   Reply With Quote
The Following User Says Thank You to FirestormFRS For This Useful Post:
carma143 (04-14-2015)
Old 04-10-2015, 09:48 PM   #3
Blu-by-U
Some Dumb Guy
Blu-by-U's Avatar
Drives: wanting an Acabian
Check your connection, there have been issues with the OBDII port early on with this vehicle. Pins disengaged and so on.
She said it was her or the car. Longest she had ever seen.
Blu-by-U is offline   Reply With Quote
The Following User Says Thank You to Blu-by-U For This Useful Post:
Old 04-14-2015, 12:05 AM   #4
carma143
carma143's Avatar
Mine is an early 2013 BRZ Limited. How would I go about fixing this, if there is indeed something wrong with the connection?
Edit: So I found this discussion http://www.ft86club.com/forums/showthread.php?t=39137 .
The OBDII device's LEDs flash correctly and connects to my phone just fine, sending rpm data, etc in real time. I'll try it with my Toyota Highlander, and my friend's 2014 BRZ Limited to see if similar issues occur.
error, fail
BRZ vs. Torque App & Cheap OBDII Adapter extrashaky Issues | Warranty | Recalls / TSB 10 04-29-2014 04:59 PM
OBDII Bluetooth and Torque app, throwing CEL BRZPDX Issues | Warranty | Recalls / TSB 11 03-03-2014 03:03 PM
HTC One V + Mount + OBDII tool + Torque App Hanakuso Audio/Visual, Electronics, Infotainment, NAV 5 02-04-2014 03:35 PM
OBDII Splitter for OFT + Bluetooth Torque App? 1Cor10:23 Software Tuning 6 11-19-2013 08:33 PM
BT OBDII/Android/Torque Confirmed working Dadhawk Engine, Exhaust, Transmission 54 12-06-2012 01:57 AM
