Old 04-08-2015, 06:58 PM   #1
Astroboy
Astroboy's Avatar
Drives: None
do the direct injector seals need to be replaced?
like somebody mentioned that the spark plugs need to be changed after 60k miles, i was wondering if the direct injection seals would need to be replaced as well?
my biggest anxiety is about driving this car and having one of my direct injector seals going out. my car is turbocharged with an Avo kit, and i pray that that wont kill the lifespan on the seals.
Astroboy is offline   Reply With Quote
Old 04-09-2015, 08:25 PM   #2
Well, like they say in the old country ..... if they ain't broke, why fix em .... ??
Old 04-09-2015, 09:38 PM   #3
DieselDog
Shift it or lose it
DieselDog's Avatar
Drives: 2014 FRS, 2003 Celica GT
There is something to be said about preventative maintenance and peace of mind.
With the failure rates i've seen on those seals from just this forum plus
60,000 miles and you're running boost.
Just change them and feel good that they are new!
DieselDog is offline   Reply With Quote
Old 04-09-2015, 10:44 PM   #4
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
unless you don't hook up your hpfp lines correctly and get to host a roadside BBQ... no pressure.
Phantom ESC, OFH, OFT, K&N Drop in
Target70 is offline   Reply With Quote
Old 04-09-2015, 11:34 PM   #5
DieselDog
Shift it or lose it
DieselDog's Avatar
Or what about if someone t bones you while driving to work?
What about if you get mugged while walking down the street?
What if the dealership actually covers that under warranty?!
For obvious reasons if you don't have any experience working with *eyerolls* High fuel pressure. Then take it to someone who can do the repair properly.
I work on 30,000psi fuel systems everyday as a tech services engineer.
the direct injector seals are not really something I would consider difficult to replace. Maybe a little bit time consuming at best because of their location.
Old 04-10-2015, 03:58 AM   #6
Target70
Target70's Avatar
it was supposed to be a joke, although I believe having the seals changed to make you feel better wouldn't be covered under warranty. Also I believe it was the dealership that incorrectly installed the hpfp line when replacing a pump for crickets on a forum members car that caused it to burn to the ground.
Old 04-10-2015, 04:28 AM   #7
juliog
juliog's Avatar
Drives: 86
The procedure for replacing DI seals is such a PITA that many shops and dealerships will refuse to do the work unless symptoms of failure are obvious. So just keep an eye on any CELs or audible knocking.
juliog is offline   Reply With Quote
Old 04-11-2015, 01:59 PM   #8
Poodles
Drives: 2015 Series.Blue
This.
If you think it's going to be some easy thing to do, you're gonna have a bad time. Watch some videos on people actually doing the repair and see that it's not something you'll want to do unless absolutely necessary.
Old 04-11-2015, 03:48 PM   #9
Astroboy
Astroboy's Avatar
Drives: None
The question I'm asking is if the di seals should be replaced at a curtain amount of miles? How often am I suppose to swap them out?
Old 04-11-2015, 03:55 PM   #10
tyrantcf
Drives: '16 WRX, CBR1000RR
The answer that you've been given is no, they don't need to be replaced at any certain mileage Unless symptoms of their failure start showing up.
If your tune is right I don't think you'd ever realistically need to change them.
Phantom ESC'd Build Thread (Retired):http://www.ft86club.com/forums/showthread.php?t=75293
tyrantcf is offline   Reply With Quote
Old 04-11-2015, 08:21 PM   #11
Astroboy
Astroboy's Avatar
Drives: None
thanks. i really appreciate it. i have bad anxiety and i worry about everything, and when i heard about all these injection failures, my anxiety sky rocketed. i remember i would also abuse this car in last summer in Texas weather with the turbo kit without checking the oil temps nor water temps, and no oil cooler.
Old 04-11-2015, 08:26 PM   #12
tyrantcf
Most of the failures were on cars that were heavily tracked and on the stock, early 2013MY tunes. So just enjoy the car
Old 04-11-2015, 11:40 PM   #13
Astroboy
Astroboy's Avatar
Drives: None
I got mine in 2012
Old 04-12-2015, 01:49 AM   #14
I got mine in 2012
Did you get the firmware updates?
Direct Injector Leaking Carwhisperer Issues | Warranty | Recalls / TSB 356 03-13-2020 12:35 PM
Injector Seals went Bad while tuning my car whitefrs Forced Induction 128 08-20-2013 12:19 PM
Direct Injector's Leaking Carwhisperer Scion FR-S / Toyota 86 GT86 General Forum 1 05-11-2013 09:31 AM
