View Poll Results: Replace HPFP?
Yes 13 25.49%
No 38 74.51%
Voters: 51. You may not vote on this poll
Old 04-07-2015, 03:24 AM   #1
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Should I get my HPFP replaced?
I'm nearing the end of my warranty. I can have the hpfp replaced if I choose to. Should I go ahead and replace it while it's free or screw it- it won't make any difference and the dealer can possible fubar my car while they're in there...?
hmong337 is offline   Reply With Quote
Old 04-07-2015, 03:44 AM   #2
irucremmi
Drives:
I'd say don't fix what's not broken. Been driving with crickets for 2 years 46k miles and no problems, and I am not aware of them anymore or maybe they are gone : )
irucremmi is offline   Reply With Quote
Old 04-07-2015, 04:53 AM   #3
Ultramaroon
not playing cards
Ultramaroon's Avatar
No.
Old 04-07-2015, 05:35 AM   #4
jlugo711
Drives: 2014 GT86
Wouldn't worry about it too much. There's nothing wrong with the fuel pump, why risk something going wrong?
jlugo711 is offline   Reply With Quote
Old 04-07-2015, 07:50 AM   #5
Mad1723
Mad1723's Avatar
Drives: Asphalt FR-S
Embrace the crickets!
Mad1723 is offline   Reply With Quote
Old 04-07-2015, 08:15 AM   #6
dentalprodigy
dentalprodigy's Avatar
Drives: 00 Accord LX, 14 FRS
I'll share another viewpoint. I knew that there was a good possibility the crickets wouldn't be fixed with hpfp replacement but I did it anyway because I'd rather have the “latest part " in the car for future warranty purposes.
That might change things since your warranty is about to expire anyways. If I was in your situation I'd get it replaced.
dentalprodigy is offline   Reply With Quote
Old 04-07-2015, 09:48 AM   #7
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
Yes.
Probably.
Maybe.
Maybe not.
Probably not.
No.
NWFRS is offline   Reply With Quote
Old 04-07-2015, 09:51 AM   #8
AznBRZer
Drives: 16 CBS WRX Limited
If it isn't knocking like a woodpecker, I wouldn't bother unless you have full 1000% confidence that they won't fuck it up. The only reason I got mine swapped was because of woodpeckers and even then, I regret it or at the very least regret that I had it done where I did.
AznBRZer is offline   Reply With Quote
Old 04-07-2015, 09:51 AM   #9
Defuser
Remember
Defuser's Avatar
Drives: 2015 Asphalt
Why not? A free, new pump. If they screw up something in the process (doubtful unless your dealer's service dept sucks) they will have to fix that.
This is my 17th car. Most fun so far!
Defuser is offline   Reply With Quote
Old 04-07-2015, 09:59 AM   #10
tyrantcf
Drives: '16 WRX, CBR1000RR
One more for no.
Phantom ESC'd Build Thread (Retired):http://www.ft86club.com/forums/showthread.php?t=75293
tyrantcf is offline   Reply With Quote
Old 04-07-2015, 10:01 AM   #11
JonAvalon
SCBYD0
JonAvalon's Avatar
Drives: 18 BRZ (WRB)
I'm currently debating it. Mine has already been replaced early last year. My service adviser in the fall said to check back early 2015 because there was suppose to be another revision. He said to come back before 36K miles regardless if I wanted another repalcement, which I am closing in on. But so far this year it hasn't been that big of a annoyance, I think I'm used to it now and just joke about it every time.
JonAvalon is offline   Reply With Quote
Old 04-07-2015, 10:46 AM   #12
MokSpeed
Granny Shifter
MokSpeed's Avatar
Drives: 2014 FR-S
If you don't have crickets then I really see no point. At first I was hesitant to get mine replaced since I was under the impression that the crickets would just come back. However, ever since I got my new HPFP in 15,000 miles ago they have never come back (knock on wood!). The choice really is entirely yours.
MokSpeed is offline   Reply With Quote
Old 04-07-2015, 10:56 AM   #13
In a way it may be worth it just to have it on record. There were at least a couple of guys that got new ones even out of warranty (buried in one of the 10 million cricket threads someplace) because the latest version was supposed to stop the crickets (it didn't but that is beside the point). If a real fix ever shows up and your dealer will play ball they just may go for it since you had it changed once already.
Old 04-07-2015, 11:30 AM   #14
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
If the dealer is known for good work, I would get it done because you will have a new HPFP with less mileage and wear and tear.
Also, if you changed it once and it's on record, you can probably ask for the new revision if it ever gets fixed.
N1rve
Is the HPFP chirp a serious problem? FRiSson Issues | Warranty | Recalls / TSB 14 12-03-2014 11:03 AM
Going on my 3rd HPFP Ryancdossey Issues | Warranty | Recalls / TSB 31 11-07-2014 01:52 PM
Weird HPFP noise Hakuzen Issues | Warranty | Recalls / TSB 19 01-29-2014 04:53 PM
Continuous BUZZ/HUM from HPFP in ACC mode. stevo_12v AUSTRALIA 2 10-22-2012 05:46 AM
HPFP and gas gague EZWood Engine, Exhaust, Transmission 2 06-16-2012 01:52 PM
