Drives: GTS86
what product will remove this stain on my bumper ?
I found this stain while cleaning my car yesterday. I've tried using wax,grease & tree sap remover spray cans and rubbing hard plus I tried using a plastic spoon to scrap it off. the thickness on the stain is about 1/10 of a mm, you can feel it but can't see the thickness.
On the bottom left a little above the grill you can see a horizontal line dent. If I was going to use a pen touch up paint, is sanding going to be required ? The dent is about 1/4 of a mm max. |
Drives: FRS!!!
Have you tried to clay it?
Drives: GR Corolla
A quality clay bar and detailer spray should be able to get that off. Not sure about the dent tho.
Drives: '13 FR-S
Try Goo Gone...
Drives: 2019 BMW ///M4
Try clay or cleaner wax.
Last resort will be meguiars ultimate compound.
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension Last edited by N1rve; 03-29-2015 at 09:40 PM. |
Drives: 2013 FR-S, Hot Lava
Very hard with out seeing it in person.
I use several steps: (in this order)(I try the least avasive first) 1-try a bug/tar or Goo Gone remove (shake the bottle, apply and let it stay on the stain for a few minutes) 2-try a paint restorer/cleaner wax 3-try a polishing compound (if you have a buffing wheel, SLOW speed and keep it moving around don't just keep it spinning in the same spot)(the orbital unit is not the best, they will leave scratches) 4-try a rubbing compound (SLOW speed, same process as the polishing, keep it moving around) 5-If you have to use the rubbing compound, go back with the polishing compound to remove any scratches you may have added. 6-Apply a Glaze 7-Apply carnauba wax 8-high speed whole bonnet |
3m wax and grease remover. Most auto stores have it.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
Drives: JDL Turbo BRZ
Laquor thinner will take that right off.
#10 |
Drives: 2015 Asphalt FR-S
+1 for clay bar and/or cleaner wax. If that doesn't work try a less aggressive polishing compound, if that doesn't work use a rubbing compound. Move from less to more aggressive.
#11 |
Sulphuric Acid
1993 Mazda MX-3 - *SCRAPPED* / 1999 Plymouth Neon - *WRECKED* / 2000 Chrysler Neon - sold / 2006 Honda CR-V - sold / 2019 Chevrolet Colorado - All Year Round Vehicle / 2013 Scion FR-S - Summer Car
#12 |
Drives: GTS86
#13 |
#14 |
Drives: 2015 Scion FR-S / Base
2015 Scion FR-S Manual Base / Stock 1970 Mustang Fastback |
| safe way to remove bumper? | Hyperian | BRZ First-Gen (2012+) — General Topics | 3 | 02-27-2014 01:11 PM |
| Way to remove the front grille without removing bumper? | brillo | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 5 | 11-24-2013 09:15 PM |
| car stain; suggestions on how to remove. | Janunez90 | Issues | Warranty | Recalls / TSB | 4 | 10-12-2013 01:59 AM |
| Best way to remove the Scion Rear Bumper Applique? | Tim_Asphalt_FRS | Cosmetic Modification (Interior/Exterior/Lighting) | 28 | 12-25-2012 01:30 AM |
| What's a good product to remove swirl marks? | Bmore_Raven86 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 6 | 10-20-2012 06:30 PM |
