Old 03-28-2015, 12:30 AM   #1
awhatzable
Drives: GTS86
Any tips on how to clip the lower part grill back onto the bumper ?
I pushed the bottom half of the grill in now I can't pull it out & clip in back on because the grill is hanging higher than the clip. Is my only option is to remove the plastic under the car so I can get my hands inside the grill?
awhatzable is offline   Reply With Quote
Old 03-28-2015, 08:46 AM   #2
FirestormFRS
Nope. Just push up on the bottom of the bumper and snap the grill in.
FirestormFRS is offline   Reply With Quote
Old 03-29-2015, 02:40 AM   #3
nos145
Cognite
nos145's Avatar
Drives: 2013 Whiteout FRS
this might sound crazy but this is how i did it:
take floss (the stuff you use for cleaning between teeth) and then thread it around the white knobs that snap into the grille.
pull it up with one hand and then pull the grille in with other.
so. use floss.
nos145 is offline   Reply With Quote
clip removal tips notout86 DIY (Do-It-Yourself) Guides 14 09-11-2015 10:19 PM
Frs lower grill trsiidno Cosmetic Modification (Interior/Exterior/Lighting) 2 01-14-2015 06:28 PM
Grillcraft Front Lower Grill in Silver for the BRZ, Availavle at RallySport Direct!! RallySport Direct Exterior Parts - The Rest 0 09-27-2013 05:21 PM
Does anyone know the clip part number? t00n3wb Cosmetic Modification (Interior/Exterior/Lighting) 1 05-20-2013 12:28 AM
Part number or name for this clip TrickyFrenchman Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 07-16-2012 10:50 PM
