Old 01-31-2014, 07:58 PM   #1
notout86
Drives: GTS 86 auto
clip removal tips
Has anyone any tips on removal of those black plastic clips/rivets/plugs/ whatever as found inside wheel arches and under the bumper.
Grit accumulates in and around the claws making them hard to remove and it is all too easy to bust them.
GTS86 Auto (Australia)
notout86 is offline   Reply With Quote
Old 01-31-2014, 08:07 PM   #2
Scion F ARE S
Drives: Toy car
Use a flat head screwdriver and pop them opened and then pull it out with your hands.
Scion F ARE S is offline   Reply With Quote
Old 01-31-2014, 08:58 PM   #3
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
These are so annoying to do. I took them off and used tie wraps. Faster removed and installed.
Rayme is offline   Reply With Quote
The Following User Says Thank You to Rayme For This Useful Post:
notout86 (09-01-2015)
Old 01-31-2014, 10:15 PM   #4
SubaSteve
Captain Cocoa
Drives: CBS BRZ MT
I swear I saw someone using some sort of tool designed to remove these clips with ease.
SubaSteve is offline   Reply With Quote
Old 01-31-2014, 11:24 PM   #5
cnk
Drives: '13 DGM BRZ Limited
I use these for plastic clips. This avoids breaking the plastic clips after they've been on the car for a while or it's cold and brittle. Using a screwdriver works, but I've found these work better for the clips where you have to pop the center out first as they apply even pressure.
http://www.sears.com/kd-tools-3-pc-b...a=00934924000P
cnk is offline   Reply With Quote
Old 02-01-2014, 04:06 AM   #6
Yamajee
Yamajee's Avatar
Drives: Rocket Bunny'd GT86
When installing my rear spats, they were such a hassle, couldn't take them off without actually using force and breaking them, but the spats came with replacement clips so yeah. Used a flathead screwdriver and used a lot of force and it would pop out after a bit.
Yamajee is offline   Reply With Quote
Old 02-01-2014, 03:39 PM   #7
Gunman
Drives: 2019 Mazda Miata RF
Like this?
http://www.harborfreight.com/push-pin-pliers-67400.html
I just picked one up, haven't tried it.
Gunman is offline   Reply With Quote
The Following User Says Thank You to Gunman For This Useful Post:
isolato (09-12-2015)
Old 02-01-2014, 10:17 PM   #8
ramiram1984
Drives: 2016 STi DGM
^they work great.
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
Old 02-08-2014, 03:06 PM   #9
hirollaz
Drives: 2013 Scion FRS 10 Series
Harbor Freight sells a pop clip plier makes removal of those clips easy.
hirollaz is offline   Reply With Quote
Old 02-08-2014, 07:18 PM   #10
mashal
DADA
mashal's Avatar
Drives: 2013
Go to a subaru dealership and buy youself a handful, they cost pennies.
Grab a flat screwdriver and start popping, worry free
mashal is offline   Reply With Quote
Old 08-31-2015, 11:36 PM   #11
xtral
xtral's Avatar
Drives: Ford Focus 09'
where did you get the tie wrap ? mind post a photo ? thanks,
I removed the clip with force and the bottom white part is cracked.
xtral is offline   Reply With Quote
Old 09-01-2015, 06:11 AM   #12
notout86
Drives: GTS 86 auto
notout86
Tie wraps ...... brilliant, at least in some applications. Thanks. Why didn't I think of them myself.
They are also known as "cable ties". Good as emergency handcuffs.
Old 09-01-2015, 08:38 AM   #13
xtral
xtral's Avatar
I don't have tie wraps ... but I used paper clips, it worked but it cracked the lock of the clip...
Old 09-01-2015, 11:28 AM   #14
Chanpion
Drives: 13 FRS Satin
Give them a wash first, remove your wheel for easier articulation and for the push clips, use a flat head screw driver into the slot between the lock clip and the base clip and just twist the screwdriver 90 degrees.
I guess maybe some WD40 would work too.
Chanpion is offline   Reply With Quote
*Groupbuy: Invidia N1 and Q300 Cat-Back Exhausts (SS tips, T.I. tips) -fteightysix* 86SPEED Groupbuys 74 11-09-2016 01:45 PM
GT5 video clip?? MR2fan FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 13 04-27-2014 11:21 PM
TRD air box clip kev1360 Engine, Exhaust, Transmission 1 07-07-2013 10:25 PM
WTB: DC Exhaust Tips or Other Tips Xdragonxb0i Engine, Exhaust, Bolt-Ons 2 05-10-2013 06:36 AM
Basic Road Salt removal tips. DetailersDomain Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 8 02-15-2013 08:27 AM
