Old 03-25-2015, 10:35 PM   #1
treymw95
Drives: 2013 scion FRS
cams oem?
A friend of mine with a civic went and got bigger cams out of a honda element fitting exact , how do you know if a cam out of another engine will fit in my frs if anything.
treymw95 is offline   Reply With Quote
Old 03-25-2015, 10:36 PM   #2
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
Nothing affordable. Besides, cam work, especially for the FA20 is a royal pain in the ass.
Bobblehead is offline   Reply With Quote
Old 03-25-2015, 11:09 PM   #3
treymw95
How so? If not how will i get the most gains n\a
Old 03-26-2015, 09:17 AM   #4
OkieSnuffBox
Drives: '23 BRZ Limited
Pour octane boost in the gas tank and 6" muffler tips.
The Following 3 Users Say Thank You to OkieSnuffBox For This Useful Post:
Basket Case (03-26-2015), cdrazic93 (03-27-2015), kch (03-26-2015)
Old 03-26-2015, 10:12 AM   #5
treymw95
How does tips give u many gains lmao
Old 03-26-2015, 11:22 PM   #6
Turdinator
Señor Member
Turdinator's Avatar
Is that just because you would have to pull the engine to do it? If I was going to the expense of cams I would be pulling it to get the heads ported anyway.
OP, the FA20 hasn't been around long enough to have a range of cams from different OEM applications available. The FB20 may have similar cams as may the FA20DIT. I would expect both of those engines to have a milder grind and without Toyota's D4S they may have a completely different setup in the head anyway. Custom or hopefully eventually aftermarket cams will be the only real way forward for NA builds in the short to medium term.
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
Ultramaroon (03-26-2015)
Old 03-27-2015, 02:21 AM   #7
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I've already contacted Kelford cams. They aren't making any, if they do they will make it for FI applications.
http://www.revvolution.com/blog/2014...he-fa20-4u-gse
That includes a lot more than cams, but gives a good explanation.
This motor isn't exactly your typical motor where you can drop in some cams and add an exhaust and get 50 whp.
The best NA gains are from the exhaust, and an E85 or race gas tune. If you're willing to spend the money; stroke and bore kits.
Old 03-27-2015, 04:55 AM   #8
Bobblehead
Bobblehead's Avatar
Yes, its because you'd need to pull the engine. With a Civic, or most any inline 4, it'd be much easier than the FA20. Thats all I was saying.
The Following User Says Thank You to Bobblehead For This Useful Post:
Turdinator (03-30-2015)
HKS Cams? BlackMonarch Engine, Exhaust, Transmission 10 02-06-2015 02:51 PM
Cams Fabron757 Forced Induction 10 01-13-2015 06:30 PM
HKS cams JesseTheFlash Engine, Exhaust, Transmission 4 01-09-2015 07:42 PM
Wtb oem cams midnight23 Want-To-Buy Requests 0 03-19-2014 12:07 PM
Cams Surok Engine, Exhaust, Transmission 10 01-01-2013 08:30 PM
