Old 03-24-2015, 08:06 PM   #1
blue_frs
blue_frs's Avatar
Need help picking sway bar(s)
I see different sizes and rates but have no idea how it all comes together. I am trying to find something that won't break the bank but still be reliable. Current suspention set up is Megan Track Coilovers. I will be buying a set of LCAs and camber bolts here soon I am aiming for -3.5F/-3R. I am trying to get parts that will make me more competative in STX.
I have heard good things about disconnecting the rear sway bar, anyone able to shed any light on this as well.
Thank you.
blue_frs is offline   Reply With Quote
Old 03-24-2015, 08:30 PM   #2
cjd
cjd's Avatar
Drives: 2017 BRZ
Spring rates? Tires?
What's the car doing (or not doing) that you want to change?
Old 03-24-2015, 08:41 PM   #3
blue_frs
blue_frs's Avatar
spring rates are 10K/8K.
also have 17x8 235/40/17 F and 17x9 255/40/17 R Federal 595 rs-r tires
i would say that i would want to get more grip. i am getting a lot of understeer at entry.
Old 03-24-2015, 09:19 PM   #4
8R6
8R6's Avatar
Drives: FRS
have you considered switching to a square wheel/tire set up instead?
8R6 is offline   Reply With Quote
Old 03-24-2015, 09:28 PM   #5
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
You have alot of options at your disposal. Check out this link for a fairly exhaustive list:
http://www.thesmokingtire.com/2012/m...teeroversteer/
With Megan coilovers, you've got plenty of things to tweak. I'd start by softening up the front. You want more grip, and that usually comes from ground contact. You can set the rears to be more stiff, depending on your current setup.
For the sake of knowledge, I present crazy old Top Gear episode with a drifting Morris Minor:
[ame="https://www.youtube.com/watch?v=shwgNV36xFA"]Car Handling - Grip, Oversteer & Understeer explained by Tiff Needell - YouTube[/ame]
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
Old 03-24-2015, 09:29 PM   #6
KoolBRZ
KoolBRZ's Avatar
Do you have an anti-dive kit installed? This adds more caster, keeping camber in check on the inside wheel during turning, helping to reduce understeer. Just got mine for $135, w/free shipping. Getting it installed next Tuesday. This also gives better high speed stability.
Old 03-24-2015, 10:26 PM   #7
kster1
kster1's Avatar
If that spring rate is 10K front and 8K rear, plus with the tire size selection, I'd focus on fixing these two items rather then patching with a sway bar (to fix the understeer, which must be massive).
kster1 is offline   Reply With Quote
The Following User Says Thank You to kster1 For This Useful Post:
Hyper4mance2k (03-25-2015)
Old 03-24-2015, 11:03 PM   #8
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Get a square wheel setup first, that's a big part of the understeer problem. Also, Federals are under 200TW and not legal this year FYI.
Old 03-24-2015, 11:21 PM   #9
blue_frs
blue_frs's Avatar
I have, and i may just give in and get the RPF1s.
also on my list of mods to get soon. thank you.
yea its just what my current set up is. im looking into getting the dunlop z2's or the brigstone re-11a's
Old 03-24-2015, 11:26 PM   #10
blue_frs
blue_frs's Avatar
definatley going to check this site out. and thank you for the tip i will be sure to give that a try next event.
Old 03-25-2015, 01:57 AM   #11
Turdinator
Señor Member
Turdinator's Avatar
Question to the more knowledgeable people here, could he swap the front and rear springs around to help balance the car out?
1974 TA22 Celica
2013 86 GT
Old 03-25-2015, 02:47 AM   #12
Yurgle
Drives: 2015 Toyota GT86 (EU Spec)
i'd don't think it is possible... as the springs front/rear might have different lenght and diameter
Yurgle is offline   Reply With Quote
Old 03-25-2015, 09:47 AM   #13
Shankenstein
Frosty Carrot
That was my first inclination too. With a bigger contact path in the back, having a front-biased setup is a bad combo.
The springs appear to be 1" shorter in the front than in the rear. You MIGHT be able swap springs, but it would slightly limit the travel in the rear.
Old 03-25-2015, 01:21 PM   #14
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
But he is on coilovers, so he could crank up the height at the bottom of the rear struts. I say you swap the springs and see how that goes. Or just buy some propper coilovers, or a decent spring and shock setup before you spend any more money trying to fix a problem that is most likely caused by the poor coilover setup.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Say no to SWAY with our Anti-Sway Bar and Sway Bar Bushing Special. FRSport.com Brakes, Suspension, Chassis 0 01-23-2015 12:38 PM
A little help picking a set up.... wootwoot Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 11-18-2014 06:41 PM
picking Up My Car Next Week - What to Look for? djmm Scion FR-S / Toyota 86 GT86 General Forum 21 03-24-2014 02:50 AM
Picking her up at 5! remorse87 Scion FR-S / Toyota 86 GT86 General Forum 14 10-07-2012 10:51 AM
Need Help Picking New Phone Calais Off-Topic Lounge [WARNING: NO POLITICS] 10 02-22-2011 04:29 PM
