Old 02-20-2015, 10:22 PM   #1
momo3605
Drives: 2014 Fr-S Monogram
Just flashed OFT Stage 2 UEL E85 tune. How long should I wait before logging?
Hi guys,
So I actually went up through the tunes gradually, from stock to 91 stage 1, then UEL stage 2, then E85 stage 2. How much driving should I do/what kind of driving should I do to speed up learning. I'm still seeing lots of fluctuations in fuel trim. When crusing my LTFTs are around 0, but it's worrying me becvause when idling it sit around 7%. On the other hand, I'm not seeing an KC so that's probably good.
Thanks!
momo3605 is offline   Reply With Quote
Old 02-20-2015, 11:44 PM   #2
swarb
All the info is contained here and in the sig of @steve99 HE DA MAN!
http://www.ft86club.com/forums/showthread.php?t=71157
Old 02-20-2015, 11:52 PM   #3
momo3605
Thanks Swarb! I did look over that thread. All it says is drive smoothly to speed up learning. I want to know how much learning is enough. For example, Do I have to rev out the engine sloowly to get it to learn trims at higher Rpms? I hope that's clear!
Old 02-21-2015, 12:09 AM   #4
swarb
lol read more. But from what I know steady state is where it does most of its learning, after that (I THINK) a couple long pulls in 3rd up to redline usually does the trick. Like entering the freeway. I'm new to oft too, so I'm still trying to figure out what readings to log and what to look out for. Maybe @steve99 can chime in. I'll gladly send him some beer money if he wrote it up!
Old 02-21-2015, 02:17 AM   #5
Kodename47
Kodename47's Avatar
Drives: UK GT86
Fuel trims are only set in closed loop operation, like cruising. Going full throttle will have little impact on trims , it's only the closed loop to open loop transition that may affect LTFT.
LTFT are set in bands, which is why you'll see different values.
.: Stealth 86 :.
Kodename 47 DJ:
Old 02-21-2015, 02:54 AM   #6
steve99
Yes ecu learns fuel trims in closed loop mode only ie smooth driving , it only needs a few minutes to learn unless your fuel trims are way out due to leaks or rearly crap maf scaling due aftermarket intakes.
Give it 10 minutes of smooth driving and a couple of those smooth partial throttle runs and it should be good to go.
dead pedal may take a few drive cycles to go.
if you maf scaling is spot on and fuel is adequate for tune ie minimal knock and iam stays at 1 then virtually no learning is required.
it learns timing corrections and fuel trims constantly adjusting if required
+1 on what @Kodename47 said
Old 02-21-2015, 03:20 AM   #7
momo3605
I noticed on my car, when I accelerate with like 40-50% throttle, the STFT start to go negative. like -7 to -8. Anyway, I drove the car for about 15 miles on the freeway cruising at like 3k rpm. Do you think I'm ready to take a data log?
Thanks!
Old 02-21-2015, 07:32 AM   #8
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
Thanks!
You must not record data logs of your car until the full moon on the third Thursday of the month. Failure to do so will result in the immediate death of a a unicorn....
Wtf are you talking about? Record logs and post em. By now your ecu has had all the time it nneeded to learn. If your trims are madly out of wack you have a leak in your gaskets. If you have an after market intake then you will see problems here as well but you already know all of this because you read Steve's thread.
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Stage 1 tune & long term reliability? autobot84 Software Tuning 2 12-31-2014 07:51 AM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 08:15 PM
How long did you wait for your tune? Silverdub Forced Induction 27 04-22-2013 10:38 PM
How long did you wait for your FR-S? polarbear Scion FR-S / Toyota 86 GT86 General Forum 192 08-21-2012 09:17 PM
