Old 03-23-2015, 06:05 PM   #1
FiendGore
Drives: Scion FRS (Firestorm)
[Question] Do wide angle kits help in Autocross/HDPE?
I have only read about autocross and was just looking for guidance on wide angle kits and if the have any affect on Autocross/HDPE driving. Thanks.
FiendGore is offline   Reply With Quote
Old 03-23-2015, 09:13 PM   #2
wparsons
wparsons's Avatar
I've never seen an autocross course that was so tight you needed more steering lock to make a turn, and if you're hanging the tail wide enough you need more opposite lock you're going much slower than you could be.
flickr
Old 03-23-2015, 10:23 PM   #3
14stu
14stu's Avatar
Drives: 2014 Subaru BRZ
If you use one you'd be put in a ridiculous class for autocross. The key to performance driving is minimizing steering.
14stu is offline   Reply With Quote
The Following User Says Thank You to 14stu For This Useful Post:
wparsons (03-24-2015)
Old 03-23-2015, 10:47 PM   #4
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
If you're using modded knuckles, you'll get more steering with smaller inputs, as the spindle arm is shortened. You'll also decrease the amount of Ackerman, which you may not want in an Autox scenario.
If you're just using tie rods, no because you're just letting the rack travel further, meaning the wheel will require slightly more rotation from lock to lock.
Furthermore, because the way the front is designed, if you add more steering angle, you'll encounter sway bar endlink bind. You'll need to either use a setup that mounts the endlink to the LCAS or ditch the away bar entirely.
In short: if you aren't drifting the car, don't bother.
TylerLieberman is offline   Reply With Quote
The Following User Says Thank You to TylerLieberman For This Useful Post:
tahdizzle (03-24-2015)
Old 03-24-2015, 08:38 AM   #5
mla163
Overthinking it
Drives: BRZ in CS
So...no.
mla163 is offline   Reply With Quote
Old 03-24-2015, 10:57 AM   #6
FiendGore
Thank you for the information. Just trying to rationalize purchasing a wide angle kit, but not seeming rational now.
Issues with Phasetek Wide angle Mirror Install Churnobyl Cosmetic Modification (Interior/Exterior/Lighting) 23 07-17-2014 01:36 PM
215 wide tire on 8.25 wide rim question barabia Tracking / Autocross / HPDE / Drifting 15 06-30-2014 08:59 PM
FS: (VA,DC,MD) Rexspeed Blue-tint wide angle mirrors SpeedLab Exterior Parts (Aero, Lighting, Etc.) 2 10-22-2013 12:55 PM
Rexspeed Wide Angle Mirrors - SOLD SpeedLab Exterior Parts (Aero, Lighting, Etc.) 3 09-04-2013 10:51 AM
Custom wide angle kit Thefear13 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 07-18-2013 12:40 PM
