Old 06-24-2014, 12:33 AM   #1
Churnobyl
Churnobyl's Avatar
Drives: 2014 Limited Subaru BRZ DGM
Issues with Phasetek Wide angle Mirror Install
Any help appreciated. The thread that appears to have some sort of instructions in it has been lock and inactivated: http://www.ft86club.com/forums/showthread.php?p=1353174
These are the rexspeed clones but with turn signal functionality.
No instructions were included...Phasetek's inbox here is full.
Mirrors snap off and on no problem. Heated mirror plug points no problem. However, included in the kit are two, two wire extensions, and 4 wire taps. But absolutely no indication of where I should be threading them to or what my source wire looks like. I'd like to get the turn signal functionality working but I'm over my head. Do I pull the door panel and go down into the door?
Churnobyl is offline   Reply With Quote
Old 06-24-2014, 01:10 AM   #2
husker741
http://www.phasteksport.com/FR-S-BRZ...rz-mirrors.htm
This looks like it has install instructions.
husker741 is offline   Reply With Quote
Old 06-24-2014, 12:49 PM   #3
Churnobyl
Churnobyl's Avatar
Does, if you buy the non wired versions. Absolutely nothing on wiring up your mirror to your turn signal, I'm beginning ot suspect it involves pulling the door panel, and running wiring all the way into the body to the harness. SO for now Mine are just heated with better view. All good.
Old 06-24-2014, 02:08 PM   #4
husker741
When I click the "installation instructions" tab it has a wiring diagram with instructions.
Old 06-24-2014, 02:20 PM   #5
Rican_D
Rican_D's Avatar
Drives: Asphalt FR-S
Maybe try the the diode dynamics video on installing the led DRL side mirrors they offer. Closest thing to what you have?
Rican_D is offline   Reply With Quote
Old 06-24-2014, 02:23 PM   #6
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
w00t for bringing to my attention that these have the heaters. thats the only thing thats been keeping me from buying the rexspeeds!
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
Old 06-24-2014, 02:24 PM   #7
husker741
@Guff- Anyway we could get that thread back open for this guy? I'm not sure why threads are closed if someone doesn't renew their sponsorship. It's not very fair for instances specifically like this.
Old 06-24-2014, 03:33 PM   #8
Churnobyl
Churnobyl's Avatar
Originally Posted by Roadcone View Post
w00t for bringing to my attention that these have the heaters. thats the only thing that's been keeping me from buying the rexspeeds!
@Roadcone, heaters work great. I'd buy from rexspeed again, since for now my turn signals are not working, and Rexspeed seems to have a bit better support. Quality is great. Heater is activated by rear defrost button. hit the button and within a couple seconds you can feel the mirror getting warm. Doesn't seem like you can screw up the wire leads for the heaters.
Old 06-24-2014, 03:50 PM   #9
illicitstylz
Drives: 2014 FRS - Whiteout - 6spd MT
[QUOTE=Churnobyl;1813471. Heater is activated by rear defrost button. hit the button and within a couple seconds you can feel the mirror getting warm. Doesn't seem like you can screw up the wire leads for the heaters.[/QUOTE]
When I replaced mine with the Rexspeed, I figured mine had the heated mirrors but could not find the button to activate it until reading your post. Thanks!
illicitstylz is offline   Reply With Quote
Old 06-24-2014, 03:53 PM   #10
husker741
Any idea why the indicators might not be working?
Old 06-24-2014, 04:34 PM   #11
Roadcone
StreetKart
i was under the impression that the rexspeed did not have the heater elements in them. are you saying they do? and yeah i know they come on with the rear defroster. i use them in the morning to get the summer dew off
Old 06-24-2014, 04:53 PM   #12
Churnobyl
Churnobyl's Avatar
Its separate wiring. I'll snap a couple pics tonight. But they include wire taps and wire leads. but absolutely no instructions. I found a this info on their site:
February 20, 2014
Reviewer: Phan Nguyen from San Jose, CA United States
installation was not straightforward for an inexperienced person. especially for the heated mirrors. the instructions(at the time i was installing) said to tap the light blue wire. tapping this made it so my car wouldn't even start. the correct wire was the large dark blue wire. otherwise these mirrors are a great value and work well. glad i purchased them!
Read more: http://www.PhastekSPORT.com/FR-S-BRZ...#ixzz35alpeMpj
Problem is in the mirror housing there is nothing that matches up to what this reviewer is posting. So for the moment I have the indicators un-powered.
Old 06-24-2014, 05:01 PM   #13
husker741
February 20, 2014
Haha crap, I thought you were a totally different person that came in the thread saying their indicators don't work. My bad!
Old 06-24-2014, 05:46 PM   #14
illicitstylz
Sorry, I mean the stock mirrors had them when I took them out.
Rexspeed does NOT
DIY: APR Door Mirror Install RallySport Direct DIY (Do-It-Yourself) Guides 53 04-26-2019 03:08 PM
Phasetek hids for winjets? WWShehan Cosmetic Modification (Interior/Exterior/Lighting) 13 02-10-2014 03:45 AM
FS: (VA,DC,MD) Rexspeed Blue-tint wide angle mirrors SpeedLab Exterior Parts (Aero, Lighting, Etc.) 2 10-22-2013 12:55 PM
Rexspeed Wide Angle Mirrors - SOLD SpeedLab Exterior Parts (Aero, Lighting, Etc.) 3 09-04-2013 10:51 AM
Custom wide angle kit Thefear13 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 07-18-2013 12:40 PM
