Old 03-17-2015, 09:15 AM   #1
lx93
Drives: 2013 BRz Premium
cooling mod for supercharger
My car has a vortech supercharger with FMIC currently making 270whp, and supporting mods includes koyo radiator and perrin oil cooler. So lately while tracking it in the 80s degree weather here in Virginia I have seen oil temperature hitting 251 degrees so I have to back out a little to let it cool down. Is that a dangerously high temperature? I am running Mobil1 0w-40.
Before getting into vented hood(I would like to retain the factory look), any other mods I could use to help with cooling under track use? thanks in advance
lx93 is offline   Reply With Quote
Old 03-17-2015, 09:15 AM   #2
lx93
I am also running Crawford AOS if that matters at all
Old 03-17-2015, 09:17 AM   #3
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
251 F oil temps aren't dangerously high, but I think the Perrin 10 row Setrab core is a bit too small for your application. I'd switch to a bigger 15 row core and measure temps with it and go from there.
Are you running a V3 or V2 Vortech SC?
The Following User Says Thank You to ATL BRZ For This Useful Post:
Dream20b (03-22-2015)
Old 03-17-2015, 10:05 AM   #4
lx93
so would bigger cooler core block more air to go into the FMIC? Right now my core is already sitting in the way of the fmic. V3 H67B is my model on the vortech.
Old 03-17-2015, 10:21 AM   #5
ATL BRZ
ATL BRZ's Avatar
The oil cooler allows air to pass through it anyways so I don't think a bigger core will make a noticeable difference to how your intercooler performs. You can always monitor Intake Air Temps before and after to be sure. If it becomes a problem you can get an oil cooler that mounts behind the intercooler like the Jackson Racing offering.
I'd be very cautious about tracking the V3.
Read these threads: http://www.ft86club.com/forums/showthread.php?t=82310
and http://www.ft86club.com/forums/showthread.php?t=71411
The Following 2 Users Say Thank You to ATL BRZ For This Useful Post:
kiichiro (03-17-2015), Koa (03-17-2015)
Old 03-17-2015, 10:59 AM   #6
ajc209
Drives: GT86 Cosworth
It not the the temps that is the issue; its the oil pressure at 120C that is worrying.....
ajc209 is offline   Reply With Quote
The Following User Says Thank You to ajc209 For This Useful Post:
Koa (03-17-2015)
Old 03-17-2015, 01:14 PM   #7
lx93
wow that's certainly alarming. thanks for bringing this up. I am currently on a trip at VIR and have 4 more days of HPDE this week (I already finished 4 days so far). I hope it will hold up till end of the week, as soon as I am back I will contact Vortech to upgrade to the V2. Anyone here want to shed some light on how much the upgrade costs?
Old 03-17-2015, 01:18 PM   #8
ATL BRZ
ATL BRZ's Avatar
I recommend using the feature on this site. http://www.ft86club.com/forums/showthread.php?t=27374
Good luck.
Old 03-17-2015, 01:52 PM   #9
Koa
Good luck.
I don't recommend you using the search feature of this site.. it's terrible.
Use google, instead.
1. Open Google.com search browser
2. Type in what you want to search for, followed by the following text: site:ft86club.com
3. Enjoy the focused search results
The Following 4 Users Say Thank You to Koa For This Useful Post:
ATL BRZ (03-17-2015), civicdrivr (03-21-2015), FRSCanuck (03-18-2015), raven1231 (03-18-2015)
Old 03-17-2015, 02:05 PM   #10
sw20kosh
Drives: 2013 Black FR-S
You can easily swap out the perrin 13 row series 6 setrab core for a 15, 20, 25 row series 9 setrab.
You may even be able to mount this core behind your intercooler depending on how flexible the intercooler mounting is (or depending on your ability to create new mounts for the intercooler). In my case, my intercooler had just enough space between it and the condenser to fit in my 25 row setrab core. Also, the radiator can be moved forwards or backwards as desired with a little bit of DIY work on the top radiator brackets.
The Following User Says Thank You to sw20kosh For This Useful Post:
CSG Mike (03-18-2015)
Old 03-17-2015, 06:48 PM   #11
lx93
Thanks for all the information people. just called up vortech and got an RA number. the upgrade costs 1000 dollars. One thing I also found is it seems like driving with AC on also helps the temperature down a bit. on a related note, my AC is not cold anymore. ugh
Old 03-18-2015, 04:29 PM   #12
lx93
ive done my searching, but see conflicting answers about whether I need a retune going from V3 to V2. some say they make same amount of boost hence no retune needed while others say they have different impeller size?
Old 03-18-2015, 05:45 PM   #13
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
A/C triggers your second rad fan generally, if the A/C isn't working the condenser won't have to release any heat because there wont be any pressure in the lines, but the second fan will probably still stay on and provide extra air flow at lower speeds.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 03-18-2015, 06:13 PM   #14
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
You will not need a retune. it is the same blower with a different unit to handle lubrication (self lubricated versus fed from the oil pan. Please see the following thread for more information:
http://www.ft86club.com/forums/showthread.php?p=1754125
It is possible to send in your current V3 blower for an oil-fed "upgrade". More information is available in the thread I linked.
BRZoomTX is offline   Reply With Quote
The Following User Says Thank You to BRZoomTX For This Useful Post:
Sleepless (03-21-2015)
Brake cooling Model Citizen Suspension | Chassis | Brakes -- Sponsored by 949 Racing 115 08-28-2018 11:28 PM
Oil and water cooling Boba_kz Engine, Exhaust, Transmission 13 08-08-2017 03:58 AM
brakes and cooling DRACHENV6 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 08-11-2013 10:34 AM
APR Performance FRS/BRZ Brake Cooling Kit vividracing Brakes, Suspension, Chassis 0 08-08-2013 04:03 PM
vortech supercharger & clutch & cooling? ft86me Forced Induction 42 07-08-2013 01:09 PM
