Old 03-12-2015, 02:00 AM   #1
HachiRo
Drives: 2013 White-Out FRS
Small, Low-lag turbo?
First, excuse my cluelessness in the subject on FI in general, but are there any small turbo kits out there? I mean ones that'll start spooling in the 1.5k RPM range, similar to that of a GTI or GenCoupe (10-12). I know it'll be a very small power boost, but will give decent kick in low end torque/power right?
Please be kind in correcting me as again, I'm new to this all. Would just be interested in a turbo that could spool quickly with small gains.
HachiRo is offline   Reply With Quote
Old 03-12-2015, 02:26 AM   #2
sw20kosh
Drives: 2013 Black FR-S
No there are none that come like that standard.
Very few want a tiny turbo that CHOKES the engine in the upper rpms. Most people who care about performance take off their stock tiny turbos and put on a turbo that allows the engine to breathe and not choke at high rpms.
If you want low end, go with a positive displacement supercharger system like the Cosworth kit, upcoming Edelbrock E-Force, or the Sprintex 210.
Old 03-12-2015, 02:30 AM   #3
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
A custom wastegated Vortech kit and get some great low end w/ power in the upper rpm range is a good option. Just my 2cents
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 03-12-2015, 06:03 AM   #4
FirestormFRS
The torque curve and modest gains you seek are not that elusive.
http://www.ft86club.com/forums/showthread.php?t=13156
FirestormFRS is offline   Reply With Quote
Old 03-12-2015, 06:40 AM   #5
Calum
That Guy
Drives: 2013 asphalt FRS MT
You beat me to it. While it isn't going to be spooled up by 1500 rpm, it will be spooled up within any normal driving if you have a standard. I haven't driven the auto, but from what I've read that will drop down to 1500 rpm, so I don't think there's any helping those. Maybe a crawford kit.
Old 03-12-2015, 07:17 AM   #6
Dammod
Dammod's Avatar
Drives: .
As the gents above have said, AVO seems to be the answer for you, with your goals in mind and a tune done accordingly.
"Some will follow your footsteps, easier than they will your advice."
Dammod is offline   Reply With Quote
Old 03-13-2015, 04:33 PM   #7
aagun
Drives: 86
use VGT turbos
aagun is offline   Reply With Quote
Old 03-14-2015, 02:07 PM   #8
KoolBRZ
KoolBRZ's Avatar
Originally Posted by aagun View Post
use VGT turbos
Like he said: VGT is a variable geometry turbo while the VNT used in most Volkswagen and Audi Turbo-Diesels is a variable vane turbo. They both use variable nozzles or vanes to control flow, rather than a waste-gate, so they can spool up at a much lower RPM. They cost a bit more, but use the same vacuum motor to operate that the waste-gates use. You would have to have a custom tune done since no off-the-shelf turbo tune is designed to handle boost at low RPM's. You would have to have custom piping, a custom tune, an electronic boost controller, and custom installation at great expense. Why not just get a supercharger instead?
anyone with small kids? brzr Scion FR-S / Toyota 86 GT86 General Forum 63 06-12-2015 11:43 AM
Part Out: Turbo Kit, Flex Fuel, Gauges, Small Battery TheDanimal Engine, Exhaust, Bolt-Ons 31 11-29-2014 12:40 AM
So I did a small doughnut.. voivoi FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 4 10-06-2014 02:29 PM
What the best way to fix a small rip in my set? speedy racer Cosmetic Modification (Interior/Exterior/Lighting) 1 06-22-2013 06:08 PM
Who ever said this car was small!! track_warrior Scion FR-S / Toyota 86 GT86 General Forum 26 08-02-2012 06:27 PM
