Drives: 2013 Raven FR-S
Does wheel weight matter that much?
This is something I've been confused about. Does wheel weight make that much if a difference in handling and acceleration? For example, if you went from a 20lb wheel to a 17lb wheel, would it make any measurable improvement?
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
1. Depends - on how the mass is distributed in the wheel. And don't forget tires...if same or less tire weight as stock then definitely yes.
2. Yes - again supposing the 20lb wheel doesn't have all the mass in the hub and the 17lb wheel all the mass in the rim...LOL
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Drives: Nevermorange FRS
Yes
It's unsprung weight and rotational mass. A heavier wheel takes more energy to spin it, has more kinetic energy while it's spinning and requires greater friction from the brakes to slow it down. A change in unsprung mass is a change against the suspension that regulates it's motion. At 3lbs per wheel, it'll be doubtful you'll notice anything. You'd have to have a well tuned suspension and a be well tuned driver along with maybe data to see the difference.
PRO86 | WTCC | STL
Drives: 22 GR86, 13 FR-S, AP2 S2000
In theory, yes.
However,I believe the impact of a few pounds is completely overstated on Internet forums. People w/ 20lb wheels run down others w/ 17lb wheels everyday on tracks all over America. Last edited by AyJay; 03-05-2015 at 11:02 PM. |
Drives: 2013 MT Asphalt FRS
Makes me want to go with a set of 16s rather then 18s.
Drives: 2017 BRZ
Depending on the nature of what you're doing, that may work for you... however, a wheel size change also brings with it a sidewall height change, and that alters performance through a corner.
![]() Always diminishing returns... Run only 2 quarts of oil and save 6-8lbs! ... ![]() You might lose more weight when the engine grenades...C |
Drives: ‘13 FRS
Personally...and this is just me...
I like to see a little sidewall on "normal" cars. About the ONLY cars that I like big wheels and low profile tires on are legitimate supercars from the 1990's onward. I always thought my car looked silly on the stock 17's. Of course, I'm only talking about cosmetics. Performance is a different thing altogether.
Drives: 15' MT FRS
What tires brand is better than the other compare to weight sizes?
Via Note 4 using Tapatalk. |
#9 | |
Drives: 2013 Firestorm FRS
Basically it comes down to, Am I really such a fast driver, that my ________(wheels, intake, tires, aero, exhaust etc etc) is what's stopping me from being 1 second faster?. For most people, it isnt anything more than a placebo. Only thing I've really found is that generally tires in the same size, but heavier, will have stiffer sidewalls and less likely to roll over and have better performance etc. Basically buy because its a good tire, not because its lightweight. If you happen to narrow the choice down to two good tires, sure, then choose based on weight...but don't eliminate tires just because they weight a few pounds more than another. |
#10 |
Im going 16's when the time comes.
You'll obtain a more true gear ratio with a 16 to a 17. you put 18 or 19's you will be going slower
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#11 |
Drives: WRB BRZ
A 3lb difference is barely noticable but in my case nearly 6lb difference between the stock rims and my OZ Alleggerita is tremendous.
Car feels lighter, Brakes easier and handles rough roads much better. |
#12 |
Drives: 1993 Impreza w/ WRX Swap + FWD!
With our cars and the low torque and low power... YES its very important and noticeable! More noticeable than with something with a lot of power and a lot more weight.
#13 |
Drives: '15 BRZ RA
If you are racing the car best choice is the 16 inch rims and tires with stiff sidewalls and good compound. This is the original spec. Otherwise, it doesn't matter too much. Choose a 17 or a 18 inch rim that you like most.
| Wheel weight, will I notice it? | Re~Mix | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 01-09-2014 02:29 AM |
| Wheel weight.. does it Matter? | karma003 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 64 | 08-22-2013 10:24 PM |
| Wheel + tyre weight | diss7 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 07-30-2013 12:16 PM |
| Light Weight Fly Wheel | denverizzles | Engine, Exhaust, Transmission | 13 | 12-03-2012 02:28 PM |
| Stock Wheel Weight | Dionysus | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 04-01-2012 01:46 AM |
