Old 07-28-2013, 11:41 PM   #1
diss7
Drives: AE86, 2x GT86, TE27
Wheel + tyre weight
It would be good to get a thread together of information of the weights of different wheel AND tyre combinations.
Wouldnt have to have pictures, just a list of text in the first post that could be sorted alphabetically, and therefore easily searched/referenced.
Everyone worries about wheel weight, without looking at tyre weight. You could argue the tyre weight was more important, as it is further out.
I'm thinking something that would just list
17x8 Wheel name 20lbs 235/40 Tyre Name 15lbs Total 35lbs username (source)
I don't mind maintaining it, if it looks as if its going to be a bit of work, that no one else wants to maintain.
Perhaps for now, reply to this thread if you have the info above, to start the collection of data.
Cheers Mike
diss7 is offline   Reply With Quote
Old 07-29-2013, 12:01 AM   #2
diss7
I guess I'll start...
17x8 Desmond Regamaster 16.2lbs 205/40 Achilles 123S 17.4lbs Total 33.6lbs
Old 07-30-2013, 06:25 AM   #3
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
Maybe just make a tire weight thread? There is already an thread with wheel weights that is pretty extensive. http://www.ft86club.com/forums/showthread.php?t=11454
Old 07-30-2013, 06:55 AM   #4
DarkSunrise
DarkSunrise's Avatar
Isn't there a flip-side to all this, where a lighter tire usually means a softer sidewall? I think that was the case with the Conti DW (very light for max summer, but soft sidewall). With a wheel, at least you can forge the wheel or flow-form cast the rim to increase strength, but there may not be much you can do with a tire.
Long story, short -- not sure the tire is the right place to look to cut weight.
2022 BRZ Build
2013 FR-S Build
Old 07-30-2013, 12:16 PM   #5
frslee
Just drive it
Drives: 13' FR-S
There are going to be a lot of combinations if you want to continue this thread. It's better by visiting tirerack for tire weight and do your own research on the weight of the wheels.
frslee is offline   Reply With Quote
WTB - GTS / BRZ 17" Genuine wheel & tyre in Melbourne VIC ZZT86 Australia Classifieds 5 06-20-2013 09:10 PM
LIST: Non-rubbing 17" wheel & tyre packages ft_sjo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 04-28-2013 06:56 AM
16" Spare wheel and tyre MACCAA Australia Classifieds 1 02-02-2013 05:35 PM
Light Weight Fly Wheel denverizzles Engine, Exhaust, Transmission 13 12-03-2012 02:28 PM
Stock Wheel Weight Dionysus Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 04-01-2012 01:46 AM
