Old 01-09-2014, 12:50 AM   #1
Re~Mix
Re~Mix's Avatar
Drives: 13' Scion FRS MT
Wheel weight, will I notice it?
I'm looking to upgrade to a 18x8.5 square setup, with Enkei RPF1 or Rays 57Xtreme's being my options.
After a bit of homework, it looks like the Enkei's weigh in around 18.5 lbs and the Rays 20.4 lbs. If I recall correctly, the stock wheel/tire combo is around 43lbs so hopefully i'll be at or under it with either setup?
FYI, I'm not racing this car often so I'm only concerned that the driving feel will be noticeably changed. Appreciate any feedback
07' Z4M Coupe | KW Clubsports | AFE Intake | Stromung Mufflers | UUC Shortshifter | Advan RS
15' 228i MSport
13' FR-S | TRD CAI | TRD Catback | UEL Header | OFT Stg 1 | Rota Grid-V | RCE Suspension | Hankook |
Re~Mix is offline   Reply With Quote
Old 01-09-2014, 01:24 AM   #2
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Can someone confirm the stock weight being 43 lbs? IIRC stock wheels are 20.6 and tires are 20 lbs.
Old 01-09-2014, 01:30 AM   #3
fatoni
You might notice the feel but you aren't likely to notice in objective performance. Not from the weight anyways
Old 01-09-2014, 01:34 AM   #4
kALMIGHTY
Drives: TRD Ultramarine '13
You'll probably feel some differences like slightly heavier steering, and more grip (depending on tires), maybe slightly slower acceleration, but most of that I would say would be due to just getting wider wheels more than the weight of the wheels themselves.
Old 01-09-2014, 01:38 AM   #5
Re~Mix
Re~Mix's Avatar
Looks like you're correct. Around 41lbs or less.
http://www.ft86club.com/forums/showthread.php?t=18950
I could go with the RPF1, they just don't seem to go as well with the Asphalt color, which in my opinion the hardest one to select wheels for.
15' 228i MSport
Old 01-09-2014, 02:11 AM   #6
diss7
Drives: AE86, 2x GT86, TE27
I have a good range of wheels, from Meisters that are more almost 10kg, to se37ks that are 6.6, and ssr's that are 4.9.
It is noticeable, but it's not massive.
I wouldn't spend thousands chasing a wheel that's slightly lighter, put it that way. Get the lightest you can.
diss7 is offline   Reply With Quote
The Following User Says Thank You to diss7 For This Useful Post:
Re~Mix (01-09-2014)
Old 01-09-2014, 02:18 AM   #7
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
This should be evaluated properly if there's not a lot of wheel/tire change experience.
Even without moving the car, you can feel a big difference between 215 contact patch and 235+ contact patch.
In the end, the wheel weight differences depend on what you're using to evaluate, and what the rest of your car is going to be like. Significantly heavier on stock shocks? You'll know. Minimal weight gain or slight loss, and JRZ coilovers? You'll know. But there's a large gray area in between that may not make any difference at all.
And more importantly OP: do you have enough driving skills to know the difference between a 45lb wheel/tire setup, vs a 50lb wheel/tire setup?
-alex
Old 01-09-2014, 02:29 AM   #8
Re~Mix
Re~Mix's Avatar
-alex
Honestly, no I do not. Which is why I am hoping to stick around stock or slightly less. I think the Rays look a helluva lot better than the RPF1, which is enough to get me to spend my hard earned money. I just don't want to feel like I'm driving a Corolla all of the sudden.
15' 228i MSport
Wheel weight.. does it Matter? karma003 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 64 08-22-2013 10:24 PM
Wheel + tyre weight diss7 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 07-30-2013 12:16 PM
Light Weight Fly Wheel denverizzles Engine, Exhaust, Transmission 13 12-03-2012 02:28 PM
Wheel/Tire Theft Notice Lonewolf Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 06-28-2012 11:05 PM
Stock Wheel Weight Dionysus Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 04-01-2012 01:46 AM
