Old 06-07-2012, 12:38 AM   #1
Evil86
Evil86's Avatar
Drives: Monkey-butt red FR-S
Ease of removing stock exhaust
It pulling the muffler easy? For autox, it is legal to pull the muffler for stock class. Less weight and more power is enticing.
Evil86 is offline   Reply With Quote
Old 06-07-2012, 01:20 AM   #2
FRSCoupe
Drives: Toyota
not sure but maybe if you replace it with something to get it out the back, otherwise the exhaust fumes probably will go into the cabin stinking up your car + deadly carbon monoxide.
FRSCoupe is offline   Reply With Quote
Old 06-07-2012, 01:39 AM   #3
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
The flange is past the axle... fumes shouldn't be a problem
To the OP -- Looks easy, two bolts and some elbow grease. However you may need to secure the end of the mid-pipe somehow (not sure about the hangers).
uspspro is offline   Reply With Quote
Old 06-07-2012, 09:05 AM   #4
Mitch
form follows function
Drives: RIP '13 BRZ
It'd probably be best to get a turn-down fabbed up. Minimal weight, but at least some direction of exhaust heat away from the body of the car.
Mitch is offline   Reply With Quote
Removing and Replacing BRZ/FR-S Intake, Air Filter and Noise Generator Delete GrimmSpeed DIY (Do-It-Yourself) Guides 99 01-25-2015 01:24 AM
Stock Exhaust Weight NYC BRZ Engine, Exhaust, Transmission 48 07-23-2013 08:13 AM
Removing interior trim dash panels ubersoph Cosmetic Modification (Interior/Exterior/Lighting) 7 05-30-2012 09:20 AM
Removing the roof antenna denkigrve Cosmetic Modification (Interior/Exterior/Lighting) 8 05-16-2012 11:59 PM
Thoughts on ease of speaker replacement? ahausheer Scion FR-S / Toyota 86 GT86 General Forum 36 11-29-2011 11:16 AM
