Old 02-28-2015, 03:46 PM   #1
Mgruver_brz
Mgruver_brz's Avatar
Drives: 2013 Lightning Red Brz Limited
Locked out no power in Keyless Entry
solved: So I just got back from a business trip and my brz has been sitting in the garage most of the winter with the occasional drive and warm ups. I went to go get in it today since I got back and it's like 25 degrees to warm it up a bit and the door was locked. Keyless entry wasn't working on either of my remote starts. The window is slightly down as well on the driver side"the little gap that slides up and down when the door gets open/closed".So Im just like completely locked out with no clue what happened or where to even start. Anybody hear of this/any suggestions?
13' limited 13,500 miles
-Thanks
Matt
Mgruver_brz is offline   Reply With Quote
Old 02-28-2015, 03:47 PM   #2
swarb
Keyhole? And check the car battery?
Old 02-28-2015, 03:49 PM   #3
DelayedBRZ
Drives: GBS BRZ, Auto Limited
Use they key!
Press the slight detent along the side of the key fob and pull out the "emergency key". This will get you into the driver's side door or the trunk if you wish to crawl through. After that try to charge the battery. I hope this helps!
DelayedBRZ is offline   Reply With Quote
Old 02-28-2015, 04:05 PM   #4
boostedbrz
boostedbrz's Avatar
Drives: 2013 BRZ Limited Turbo E85
I thought the keyhole was just for decoration?
boostedbrz is offline   Reply With Quote
Old 02-28-2015, 04:10 PM   #5
stugray
Drives: 2013 GBS BRZ Limited
http://lmgtfy.com/?q=locked+out+of+my+brz
Old 02-28-2015, 04:20 PM   #6
Mgruver_brz
Oh wow I didn't realize the key was in the remote start like that, I felt like a dumbass for asking but that helped a lot lol. I'm sure it's just the battery but even still the remote start typically works. I'll give it a try, Thanks!
Old 02-28-2015, 05:09 PM   #7
White64Goat
My battery ran down too but I left the doors unlocked when I put it in the garage...........
Old 02-28-2015, 05:13 PM   #8
Mgruver_brz
Yeah I actually think I found the culprit. My window wasn't sealing shut so I guess that was enough to drain the battery, I had to put it the whole way down and back up before it sealed. The cold does funny things. But yeah I knew the car had keyholes I just didn't realize that's where the key was lol.
Old 02-28-2015, 05:15 PM   #9
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
FYI: I grabbed this from the manual, should be helpful
PandaSPUR is offline   Reply With Quote
dead no entry brz limited
FRS, Lost key and keyless entry module roggt86 Scion FR-S / Toyota 86 GT86 General Forum 2 12-29-2014 08:35 AM
keyless entry not working ninjasaurusrex Scion FR-S / Toyota 86 GT86 General Forum 0 06-06-2014 09:08 AM
Keyless Entry Upgrade Tr1huynh Electronics | Audio | NAV | Infotainment 3 02-24-2014 08:07 PM
Do we really have keyless entry? ZackZ Scion FR-S / Toyota 86 GT86 General Forum 4 10-22-2013 10:04 PM
BRZ Keyless entry? Motopythons CANADA 7 06-03-2012 05:56 PM
