Old 06-09-2012, 09:39 PM   #1
jello
Drives: DC5R
AuDM GT/JDM G brakes
I figured I should ask a brake related question in the brake related forum.
The Australian GT specification is similar to the Japanese G specification 86. This means they have 16" wheels and smaller brakes compared to the AuDM GTS/JDM GT/USDM FRS/global BRZ.
Looks like you guys have figured out which Subaru the 17" brake package shares its part numbers with, but what about the 16" brake package? Are the calipers and pads the same as the 17"er? What other car uses the 16" car's discs?
This is all I know of the Australian brake package:
The GT and GTS also have front ventilated disc brakes, but the discs are different sizes: the GT has 277mm diameter fronts and 286mm rears, while the GTS has 294mm diameter fronts and 290mm rears.
jello is offline   Reply With Quote
Old 07-18-2012, 08:31 AM   #2
Paragon
Guest
Posts: n/a
Bump, the smaller rear rotor are also not ventilated unlike the largerversion rears
Old 07-18-2012, 03:20 PM   #3
jamal
jamal's Avatar
Drives: Legacy GT
The "17 inch" brakes will still fit under 16" wheels.
The rear pads on the 16" brakes are different than the bigger brakes I think. They should be the same parts as the 08-11 Impreza and WRX.
The front pads are the same, and uses the rotors from the regular non-turbo Impreza. That rotor size has been around since the 91 turbo legacy, and was on a ton of other cars.
Here's just about anything anyone would want to know about stock Subaru brakes:
http://forums.nasioc.com/forums/show....php?t=1265631
jamal is offline   Reply With Quote
Old 07-18-2012, 06:22 PM   #4
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
Wow, I never knew we peeps with 16s were getting smaller brakes too!
Gonna be a PITA finding pads now. :p
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 07-20-2012, 06:55 AM   #5
bet00ST
Drives: Wallabies
bet00ST is offline   Reply With Quote
Old 07-22-2012, 01:44 AM   #6
Camotec
Large Member
Camotec's Avatar
Drives: Toyota GT86 - Silver
I am also interested in the Part numbers. I have not received my 86 yet, so I am unable to check. I am looking at putting on bigger rotors (DBA 5000 T3 Series). If they are the same part number caliper and I just need a different rotor and possibly pads that would be ideal.
Camotec is offline   Reply With Quote
Old 07-23-2012, 12:23 PM   #7
ultra
Curious cat.
ultra's Avatar
Gonna have to keep my eyes peeled on the Aussie threads for info I guess.
Old 12-11-2012, 06:04 AM   #8
Snake
Drives: ADM Toyota 86 GT
The best I can find is that the brake pads for the 277mm GT brakes are the same as the 294mm GTS brakes but that doesn't seem right to me. I had a quick look at the fronts on mine vs the fronts on a GTS and the caliper looks much smaller. It was a very quick look so I might be wrong.
Hawk list them as the same pad which means you can get the Hawk HP+ for track work. I'm still not convinced so it would be good if someone could confirm that this really is the case. Otherwise I will whip a pad out next year before the track work begins and let you all know.
http://www.hawkperformance.com/docs/catalog-current.pdf
Snake is offline   Reply With Quote
Old 12-11-2012, 04:57 PM   #9
Panman
Panman's Avatar
Drives: 86 GTS
Definitely wrong - TRD lists different pads for the rear of the GT - Remember Hawk are basing their stuff off USDM cars.
Also remember that in the UK GT86 is the designation for the car that we have in Australia as the GTS so that will add some extra confusion outside of Australia.
Panman is offline   Reply With Quote
Old 12-11-2012, 05:07 PM   #10
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Front pads are the same IIRC, rear pads are different.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-11-2012, 07:31 PM   #11
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
I don't understand why they felt the need to call the car so many different things.
SubieNate is offline   Reply With Quote
Old 12-12-2012, 03:56 AM   #12
Snake
Is anyone able to confirm this is the case? I am only going to change the front pads anyway, the rears don't do enough to bother.
Old 12-12-2012, 05:59 AM   #13
Panman
Panman's Avatar
Drives: 86 GTS
Can absolutely confirm that the front pads are the same on all models FR-S/BRZ/86 - rears vary.
Old 12-02-2013, 08:03 PM   #14
jonbatz01
jonbatz01's Avatar
Drives: ZD8
Very old thread but i want to confirm.
Are the brake Pads for the Front same across the AUD GT vs the AUD GTS/FRS/BRZ?
EOJ | PERTH | ZD8
jonbatz01 is offline   Reply With Quote
GT brakes jello AUSTRALIA 2 06-10-2012 09:10 AM
OEM Brakes, not as standard Subaru as I had hoped.. Dave-ROR Suspension | Chassis | Brakes -- Sponsored by 949 Racing 41 04-16-2012 07:34 PM
forgo foglights for air duct to cool brakes? Slide Scion FR-S / Toyota 86 GT86 General Forum 13 11-30-2011 07:58 AM
convert drum to disk brakes DIG1992 Other Vehicles & General Automotive Discussions 2 11-09-2011 05:04 PM
Brakes, track set up? CyberFormula Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-29-2010 08:16 PM
