Old 04-10-2012, 12:28 PM   #1
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
OEM Brakes, not as standard Subaru as I had hoped..
So in prep for a track day I was hoping to do within days/a week of getting the car (assuming timing worked out) I had started to research brake pads for the car. Sadly, the only matching part number is the front rotors. They are WRX front rotors.
Not that I care about the rotors specifically, but I first checked the pads. They don't match an existing Subaru, no big deal, compound differences would mean a different part number, but the caliper is what's more important. Unfortunately, the calipers also don't match any existing Subaru part numbers.
I PMd some Toyota guys on here just in case they are Toyota parts but from what we know right now we may have to wait a bit for pad upgrades for the car
I have contacted Carbotech about it to see if they can pull the info from Scion/Subaru and make some pads for me in advance. Otherwise, I'll throw my car up on the lift and leave it for a few days and ship my pads to them so they can find the matching pad, or create new pads for the cars.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-10-2012, 01:28 PM   #2
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Wow, I'm really surprised about that. I figured they used WRX hardware all around. Hmm...
Old 04-10-2012, 01:41 PM   #3
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
oh noes! this is really interesting news.
WingsofWar is offline   Reply With Quote
Old 04-10-2012, 01:52 PM   #4
2fast4you
2fast4you's Avatar
Drives: 2006 Scion tC RS 2.0
I'm slightly disappointed, but not surprised.
Brake. Turn. Accelerate. Repeat as necessary.
2fast4you is offline   Reply With Quote
Old 04-10-2012, 01:54 PM   #5
OrbitalEllipses
Drives: Attitude
Interesting. I hope it uses a common d number pad shape. Otherwise . Let's bank on it being a known Toyota P/N. Perhaps someone knows someone in Japan that can access the TRD pads and get their d number?
Old 04-10-2012, 02:00 PM   #6
colHolm
Default User Title
colHolm's Avatar
All the part numbers that I can see are all Subaru, which means there isn't an easy way to find out if there are any shared vehicle applications (on the Toyota side at least).
colHolm is offline   Reply With Quote
Old 04-10-2012, 02:10 PM   #7
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I was figuring WRX fronts and LGT rears because of the vented rear discs, WRX calipers wouldn't have worked for that.
I have no idea why they went a different route, unless they are the normal parts just with new part numbers due to the switch in sides (R becomes L when the caliper switches front the back of the wheel to the front to keep the bleeder up top).
One of the Toyota guys replied, they are Subaru PNs in the Toyota system, so no go on them being Toyota parts.
I haven't heard back from Carbotech yet but I doubt they'll have info yet. No pads listed on tirerack or online that I could find to cross reference part numbers with either.
Hopefully the rear rotors will become common on something else so replacements with be cheap
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-10-2012, 02:10 PM   #8
OrbitalEllipses
Drives: Attitude
Didn't the Toyota-side shop and info manuals go live? I would think there might be a breakdown of the pad shapes front/rear there.
Old 04-10-2012, 03:01 PM   #9
Racecomp Engineering
Don't sweat it guys. There are lots of little things that could change and necessitate a part number change. Piston sizes on the caliper, pad compound, etc....we weren't expecting these things to stay the same.
The important thing is the pad shape and I'm fairly certain that's the same as WRX. I will double check our notes.
- Andrew
Old 04-10-2012, 03:05 PM   #10
Yeah the pad shape matched our 2011 WRX.
- drew
Old 04-10-2012, 03:06 PM   #11
2fast4you
2fast4you's Avatar
- Andrew
Thanks Andrew!
Old 04-10-2012, 03:09 PM   #12
OrbitalEllipses
Drives: Attitude
- drew
Excellent news, thanks RCE & crew.
Old 04-10-2012, 03:10 PM   #13
Also on that note....the brake bias on this car is soooo damn good (for a Subaru especially) and it stays pretty darn flat under hard braking. Really impressed with that.
Which naturally means that a lot of aftermarket BBK's are gonna seriously ruin the braking on this car in my opinion.
- drew
Old 04-10-2012, 03:11 PM   #14
No problem guys, glad to help!
- drew
MotoIQ: Tech Look at FR-S Underside - Suspension, Chassis, Brakes, Differential oneday Suspension | Chassis | Brakes -- Sponsored by 949 Racing 93 09-22-2017 10:47 AM
forgo foglights for air duct to cool brakes? Slide Scion FR-S / Toyota 86 GT86 General Forum 13 11-30-2011 07:58 AM
convert drum to disk brakes DIG1992 Other Vehicles & General Automotive Discussions 2 11-09-2011 05:04 PM
Brakes, track set up? CyberFormula Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-29-2010 08:16 PM
