Old 02-21-2015, 11:10 AM   #1
DetailersDomain
DetailersDomain's Avatar
Drives: Audi S4
Winter Car Care Tips - Salt Removal
Winter Car Care Tips - Salt Removal Wash
Helpful Winter Tips
  • Keeping your vehicle as clean as possible during the winter will go a long way to cut down the damage done by salt and sand.
  • Take your vehicle to the car wash as often as possible. If you can get to your undercarriage as well that would be a plus.
  • Make sure to protect your car with your favorite wax or sealant.
Make sure the car is completely dry
  • Carefully dry the edges of the doors inside and out, including the undersides of door handles, all hinges, plus the hood and trunk edges. This helps keep them from freezing shut.
  • Use a good quality spray protectant on all exterior rubber or vinyl surfaces. It may be best to spray they applicator you are using instead of spraying the product directly onto the surface. This will avoid any overspray onto the paint.
This BMW 435 X Drive receives a salt removal wash and protect.
Salt Removal - Wash and Protect
Our special pre-soak was designed to chemically remove the majority of the salt and road grime off the paint, with our touch less approach we are preserving the condition of the paint.
After shot
Interior Mats - Salt Removal - just as important make sure your interior is free and clear of salt as it will cause long term damage to your interior bits and pieces.
Before
After
DetailersDomain is offline   Reply With Quote
Old 02-21-2015, 02:58 PM   #2
BRZnut
Drives: BRZ DGM Limited
perfect timing! What is the best why to remove the salt from the Mats??? How did you do it?? Wash them??
Old 02-21-2015, 07:21 PM   #3
DetailersDomain
Drives: Audi S4
depending on how bad your mats are you can use the following
Interior Brush
1Z einszett Plastic Deep Cleaner
Microfiber Towel
Metro Vac
What we did on the Porsche mats were spritz the plastic deep cleaner on the mats, then we used a brush to agitate, then a clean towel to pull the salt from it. After did a nice vac on them.
Old 02-22-2015, 10:47 AM   #4
BRZnut
Interior Brush
Microfiber Towel
Metro Vac
Thanks! Going to be above freezing today and need to clean up my BRZ!
Old 02-22-2015, 10:49 AM   #5
Wilso
"Patience young Padawan"
Drives: 2017 Crystal White BRZ
How do you suggest we care for the salt and stuff when we don't have the luxury of an inside spot to wash the car?
Wilso is offline   Reply With Quote
Old 02-22-2015, 11:19 AM   #6
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
You're just fucked then.
There are a few ways.
[ame="https://www.youtube.com/watch?v=M1nI7Td5eqA"]How to Wash your car in Winter: Ferrari F40 - YouTube[/ame]
You can google for a few other. The rinseless wash can work as well...note the word can.
Personally, i go to one of the self car washes and just wash off the salt with the high pressure water. I still have synthetic wax on car which does last me the whole harsh winter, which is why i don't use any of the soap from the self wash places - since the soap can remove the wax. I also don't dry the car either, since i know there's still dirt on the paint that will only cause swirl marks.
Old 02-22-2015, 02:20 PM   #7
DetailersDomain
Drives: Audi S4
Old 02-22-2015, 02:21 PM   #8
DetailersDomain
Drives: Audi S4
do what Larry is doing in the video, but cost are high for a good steamer, or go to a good coin op or touch less wash, or a trusted detailer in your area.
Old 02-22-2015, 07:33 PM   #9
Mikeez
Engineering Student
Drives: Scion FR-S 2015
Is there a spray that I can use to remove grime and dirt?
I want to rinse the car, spray "special spray that you will recommend" and then rinse the car again and 70-90% of the dirt and grime is removed... without touching the car?
Then I will do an agitated car wash.
There’s no time to stop for gas, we’re already late
Mikeez is offline   Reply With Quote
Old 02-22-2015, 08:04 PM   #10
DetailersDomain
Drives: Audi S4
Our special pre soak is listed here - Pre Soak for Salt Removal
clip removal tips notout86 DIY (Do-It-Yourself) Guides 14 09-11-2015 10:19 PM
All Season Detail - Salt Removal - 14 Audi RS5 DetailersDomain Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 03-11-2014 12:24 PM
Need floor mats for winter (daym salt) Brahsbrah Cosmetic Modification (Interior/Exterior/Lighting) 2 10-01-2013 11:50 PM
Basic Road Salt removal tips. DetailersDomain Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 8 02-15-2013 08:27 AM
