Old 02-09-2015, 06:12 PM   #1
ChrisD
ChrisD's Avatar
Drives: GT86
Axle stands
So we don't seem to be able to actually get to the axles on these cars... so at the moment when I get the GT86 up on to axle stands I'm just putting them where the jacking points are on the edge of the car near the wheels. I've been using a block of wood with a groove cut down the middle to spread the weight out a little (so that we can jack it up on the wood then slide the axle stand in next to it) and also the wood makes it fit nicely in to the axle stand "cup".
But I assume there must be a better and less sketchy way of doing this than using bits of wood... I think I saw one guy one here had some polyurethane parts custom made up for this purpose, but are there no pre made parts we can buy for this? What does everyone else do when they want to work under the car?
ChrisD is offline   Reply With Quote
Old 02-09-2015, 06:34 PM   #2
Marx
Marx's Avatar
Drives: '13 Lava FR-S 6MT
You could get something like these, I don't know if they fit the jacking points perfectly but it's a bit better:
http://www.harborfreight.com/2-piece...and-95952.html
Marx is offline   Reply With Quote
Old 02-10-2015, 01:29 AM   #3
humfrz
Cement blocks and blocks of wood have worked for years ..... why over engineer the project ..
humfrz
Old 02-10-2015, 02:00 AM   #4
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
What I do:
[ame="https://www.youtube.com/watch?v=Kq8h6ra9s2I"]https://www.youtube.com/watch?v=Kq8h6ra9s2I[/ame]
(rubber blocks on factory lift point front, wherever it falls in rear...)
Will never go back to jack and jack stands!
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
The Following User Says Thank You to Vracer111 For This Useful Post:
finch1750 (02-10-2015)
Old 02-10-2015, 02:17 AM   #5
Ultramaroon
not playing cards
Ultramaroon's Avatar
Idea taken from another thread here. Too lazy to look for it.
Hockey pucks.
Old 02-10-2015, 08:59 AM   #6
Caspeed
Caspeed's Avatar
Drives: FRS-RS1, Triumph Speed Triple, Lola
humfrz
Because; Cement blocks are prone to sudden structural failure. Which leaves the car sitting on you arm, chest, leg or whatever is under the car.
Caspeed is offline   Reply With Quote
Old 02-10-2015, 11:13 AM   #7
humfrz
Hello @Caspeed ......
Let's see here ...... according to the inter-web, a well made (in the US of A) cement block, has a compression strength of 1900 psi.
A 8"x8" block would have the surface area of 16 sq. in.
16 x 1900 would = 30,400 lbs per block.
A FR-S/BRZ weighs about 2,800 lbs.
Therefore, one cement block should hold up about 10 FR-S cars.
I'll trust my body under cement blocks and 4x4" wooden blocks ...... any day ....... over "made in Taiwan" jack stands.
Hey, lemmie alone ....... I'm old .......
humfrz
Old 02-10-2015, 11:28 AM   #8
Koa
overthinking things is a hallmark sign of a true enthusiast.. carry on bros
The Following 3 Users Say Thank You to Koa For This Useful Post:
8R6 (02-10-2015), killboy (02-17-2015), Ultramaroon (02-10-2015)
Old 02-10-2015, 11:35 AM   #9
humfrz
One concrete or cinder block ("cement" is just a small part of concrete) can also shatter in a second if the weight is not dispersed over the entire surface evenly!
Old 02-10-2015, 11:38 AM   #10
Caspeed
Caspeed's Avatar
humfrz
Ah yes Darwin at his best... I'm old too.... Too damn old.... and I've seen them fail...with no warning...But you're a big boy take your risks as you wish. Good Luck!
Old 02-10-2015, 11:41 AM   #11
Hockey pucks.
Sacrilege!
Old 02-10-2015, 12:04 PM   #12
humfrz
OK, I'll be careful .....
humfrz
Tcoat (02-10-2015), Ultramaroon (02-10-2015)
Old 02-10-2015, 12:12 PM   #13
I use this one when I do my hazard analysis sessions for new hires:
humfrz (02-10-2015), Ultramaroon (02-10-2015)
Old 02-10-2015, 12:15 PM   #14
Ultramaroon
not playing cards
Sacrilege!
lol! As I was taking the picture I thought of you. Didn't you say once that you were a bad Canadian for not really being into it? Maybe that was someone else.
jack stands oil change. Howardwei Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 04-02-2019 11:45 PM
Alignment at home using hub stands.. diss7 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 06-25-2014 04:52 AM
Japanese jack stands? Augora Scion FR-S / Toyota 86 GT86 General Forum 4 05-26-2014 12:59 PM
Jacks/stands around central nj? Reflex NY / NJ / CT / PA 9 09-13-2013 11:30 AM
ramps + jack stands so26 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 04-23-2013 04:43 PM
