Old 03-03-2014, 01:14 AM   #1
Howardwei
jack stands oil change.
I was wondering if jacking up the car only up fronts and hold the car with 2 jack stands would prevent all the oil form coming out since it would be incline?
Sorry if some one posted this. but I could not find it somehow.
Howardwei is offline   Reply With Quote
Old 03-03-2014, 02:12 AM   #2
humfrz
Oh, I figure most of it will drain out......
Not to worry about the two spoonfulls left.
humfrz
8RZ (03-25-2019), Howardwei (03-03-2014)
Old 03-03-2014, 02:17 AM   #3
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
I was going to ask the same thing
Carlitoz3 is offline   Reply With Quote
Old 03-03-2014, 10:30 AM   #4
humfrz
Yep, it's good to leave a few molecules of the old oil in the crankcase to introduce the new oil molecules to the engine parts ..... so as they don't go into .... "hydrocarbon shock" .......
humfrz -
soundman98 (03-24-2019), Stang70Fastback (03-25-2019)
Old 03-04-2014, 02:23 PM   #5
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
has anyone tried it?
Old 03-04-2014, 02:25 PM   #6
fender9530
fender9530's Avatar
Drives: Asphalt FR-S
I've done it. Doesn't worry me to have a little extra left. You could just jack up the rear to level it while draining.
fender9530 is offline   Reply With Quote
Old 03-04-2014, 02:26 PM   #7
vividracing
vividracing's Avatar
That's usually how I do it.
vividracing is offline   Reply With Quote
Old 03-24-2019, 09:05 PM   #8
Seiryuu
Drives: ZC6
I have this same question and I don't want to make a new thread. I guess it's a given that there will be more leftover oil with just the front up than if you were to have the car leveled. So does anyone know roughly how much more extra oil will be left compared to draining while leveled?
Thanks!
Seiryuu is offline   Reply With Quote
Old 03-24-2019, 11:46 PM   #9
soundman98
ProCrastinationConsultant
soundman98's Avatar
Thanks!
thanks for searching!
officially, the oil pan holds something around 5.7qt's, this says somewhere near 5.2-5.4 qt's.. i have 5.4-5.7 written on my filler cap. it really depends on how much comes out, which depends on overall viscosity, where the oil was before you drained it, and how long you allow it to dribble out.
in practice i'm typically around 5.5-5.7qt's.
Old 03-25-2019, 12:22 AM   #10
86MLR
86MLR's Avatar
I put it up on 4 stands, while the oil is draining I inspect all bushings and fixtures.
And then rotate tyres.
Yes, every time.....because vehicle maintenance is fun.
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
The Following 6 Users Say Thank You to 86MLR For This Useful Post:
DarkPira7e (03-25-2019), MuseChaser (03-25-2019), new2subaru (03-25-2019), soundman98 (03-25-2019), Spuds (03-25-2019), Ultramaroon (03-25-2019)
Old 03-25-2019, 06:48 AM   #11
DarkSunrise
DarkSunrise's Avatar
This is typically how I drain the oil and haven't had any issues. I'll put it on 4 stands when it needs to be level though (like rear diff and transmission fluid changes).
2022 BRZ Build
2013 FR-S Build
Old 03-25-2019, 08:41 AM   #12
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I just drive onto ramps. Same thing, less work. It's fine if you're not doing a 100% oil change, as long as 90% of it comes out. Having it up on all 4 is nice sometimes because it lets you creep under there to check on everything. See how your exhaust flanges look, check for oil leaks, check wheel bearings...
Old 03-25-2019, 11:42 AM   #13
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Isn't the drain plug at the back edge of the oil pan? Wouldn't the car leaning backwards slightly get more oil out? What am I missing?
And there's always going to be some oil left over. It's fine, don't worry about it.
The Following User Says Thank You to Spuds For This Useful Post:
Sapphireho (04-02-2019)
Old 03-25-2019, 12:04 PM   #14
mrg666
pessimistic skeptic
mrg666's Avatar
If you flip the car upside down and spin it while draining, you can drain the oil completely from oil filler. And, as an added benefit, you don't need to change oil drain plug washer this way.
The Following User Says Thank You to mrg666 For This Useful Post:
Jack Stands + Pinch Weld Wyattkb Scion FR-S / Toyota 86 GT86 General Forum 36 10-12-2015 03:45 AM
Car's sitting on jack stands while waiting for new wheels. hanabie DIY (Do-It-Yourself) Guides 9 02-08-2014 02:03 PM
Jacks/stands around central nj? Reflex NY / NJ / CT / PA 9 09-13-2013 11:30 AM
ramps + jack stands so26 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 04-23-2013 04:43 PM
The S in September stands for Suspension! Lots of Sales! KronosPerformance Brakes, Suspension, Chassis 8 09-13-2012 02:08 PM
