Old 05-30-2014, 03:05 AM   #1
diss7
Drives: AE86, 2x GT86, TE27
Alignment at home using hub stands..
What do people think of these..?
http://www.bbxracing.com/product_inf...products_id=69
diss7 is offline   Reply With Quote
Old 06-24-2014, 12:38 AM   #2
lazyluka
Drives: GT86
Bump. Anyone?
lazyluka is offline   Reply With Quote
Old 06-24-2014, 10:55 AM   #3
ToyoburuBRZ
ToyoburuBRZ's Avatar
Drives: Black BRZ
I have seen these used before but mostly for actual race cars. There are Formula SAE teams that have started to use this system in the last few years and I've also seen it used in the professional racing series.
The only problem with these for our car would be setting up toe. To set up toe you require a second system that would run from the front of the car to the rear of the car (most people use string) and it must be perfectly parallel to the car. You can see in the bottom right corner of the picture that you need that to do toe measurements.
If our car had two tow hook points on the front like it does in the rear, it could be very simple. The way it is typically done is by have a rod run across the front and rear of the car with a small notch about 4 or 5 inches outside of the vehicle. These notches need to be perfect to ensure the string runs parallel to the car. You then place a string over each notch from front to rear and hang a weight from each end of the string to keep it taught. Then you can measure toe.
If you can create a system like that then these things are great. But personally, unless you want to change you alignment every weekend like a race team does, I don't see spending that kind of money to be worth it as you can typically get an alignment for less than $100.
ToyoburuBRZ is offline   Reply With Quote
Old 06-25-2014, 05:52 AM   #4
dobbrz
Drives: RB v1 FRS
They work. There is a guy local to me who does alignments for me and a few others using these
dobbrz is offline   Reply With Quote
jack stands oil change. Howardwei Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 04-03-2019 12:45 AM
Japanese jack stands? Augora Scion FR-S / Toyota 86 GT86 General Forum 4 05-26-2014 01:59 PM
jack stands in the peninsula?? Shindig Northern California 2 04-28-2014 01:28 PM
ramps + jack stands so26 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 04-23-2013 05:43 PM
