Old 02-07-2015, 06:09 PM   #1
sledheadguy
Drives: 2014 FRS firestorm red (MT)
what the hell is lift-throttle oversteer?
been reading up on the reviews of my frs. what is lift-throttle oversteer?
I think it came from a car and driver review.
sledheadguy is offline   Reply With Quote
Old 02-07-2015, 06:15 PM   #2
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
When you lift, there is a weight transfer from the rear wheels onto the front wheels. That means more traction on the front, and less traction on the rear.
So if you lift while cornering, there is an increased tendency for the rear end to slide out. Hence "lift-throttle oversteer."
billwot is offline   Reply With Quote
The Following 3 Users Say Thank You to billwot For This Useful Post:
BRZZZZZZZZZZ (02-11-2015), M-17 (02-10-2015), themadscientist (02-11-2015)
Old 02-07-2015, 06:20 PM   #3
sledheadguy
ok....so is this a positive or negative???
I would think its a negative.
Is it a big deal? what can fix it?
Old 02-07-2015, 06:23 PM   #4
86_Freak
86_Freak's Avatar
Drives: 2015 FR-S
Depends on what you are trying to do. Sometimes it can help you get some rotation in a corner if needed, but usually it catches drivers out and makes them spin. You really have to be pushing the car to get it the lift-throttle oversteer, though, and the traction control has to be off.
86_Freak is offline   Reply With Quote
The Following 4 Users Say Thank You to 86_Freak For This Useful Post:
BRZZZZZZZZZZ (02-11-2015), M-17 (02-10-2015), sledheadguy (02-07-2015), themadscientist (02-11-2015)
Old 02-07-2015, 06:24 PM   #5
billwot
Well, if you autoX or do track days, its definitely a positive. Swinging the rear end out is a quicker way to make a corner.
Toyota even equipped us skinny tires to make it easier to swing out the rear end.
The Following User Says Thank You to billwot For This Useful Post:
Old 02-07-2015, 06:26 PM   #6
Grim-Reaper
Grim-Reaper's Avatar
Drives: GT86 '13 AT, Supra 3.0i Turbo' 91
That is what got some Porsche 911 owners a bad day. Old 911s are sensible on throttle lifting.
Grim-Reaper is offline   Reply With Quote
Old 02-07-2015, 06:30 PM   #7
billwot
2nd gen MR2s are too!
The Following 6 Users Say Thank You to billwot For This Useful Post:
BRZZZZZZZZZZ (02-11-2015), FRSupra (02-09-2015), Muaddib (02-07-2015), NWFRS (02-07-2015), N_A (02-09-2015), sledheadguy (02-07-2015)
Old 02-07-2015, 06:34 PM   #8
Dake
Dake's Avatar
Yep, conversely, if you're right on the edge of grip and take your foot off the gas - around you'll go.
Dake is offline   Reply With Quote
The Following User Says Thank You to Dake For This Useful Post:
Old 02-07-2015, 06:36 PM   #9
Teseo
Drives: frs
S2000 also, you can "fix" it with griper tires, soft suspension in the rear
and sometimes less presure in the rear tires also aid
The Following User Says Thank You to Teseo For This Useful Post:
Old 02-07-2015, 07:36 PM   #10
jdubious
Drives: 13 Scion FR-S
Learn something everyday. This day was noteworthy.
jdubious is offline   Reply With Quote
Old 02-07-2015, 07:38 PM   #11
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
These front-engine cars are relatively immune.
It's really only likely to 'catch you out' in a mid/rear or rear-engine car.
And only then if you're really pushing it through a corner, as was mentioned.
Most of the mid/rear engine cars have around a 42/58 weight bias. Pretty far from 50/50.
http://en.m.wikipedia.org/wiki/Lift-off_oversteer
NWFRS is offline   Reply With Quote
The Following User Says Thank You to NWFRS For This Useful Post:
strat61caster (02-07-2015)
Old 02-07-2015, 07:41 PM   #12
MightyMeeple
Slower than Fast
MightyMeeple's Avatar
Drives: BRZ Limited 6MT
Wrong...wrong...wrong. Maybe fun, but not a benefit in most situations. If your tires are sliding and therefore not gripping, in most cases you are losing time.
MightyMeeple is offline   Reply With Quote
The Following 13 Users Say Thank You to MightyMeeple For This Useful Post:
Akari (02-09-2015), Andrew025 (02-10-2015), AznKirby (02-11-2015), CatDaddysBBQ (02-09-2015), chrisl (02-10-2015), civicdrivr (02-09-2015), drewbot (02-10-2015), D_Thissen (02-07-2015), M-17 (02-10-2015), Manic (02-12-2015), stevesnj (02-07-2015), tahdizzle (02-09-2015), Ultramaroon (02-10-2015)
Old 02-07-2015, 07:45 PM   #13
Like said you can change it with suspension tweaks but you are not really "fixing" anything as it isn't broken.
Now having said that it also isn't a problem for your average day to day driving but more of an occurrence when pushing the car to it's limits Again like said the guys tracking actually want it to some extent. I will sometimes do it on purpose when entering an on/off ramp when I am feeling playful!
Old 02-07-2015, 08:01 PM   #14
stevesnj
stevesnj's Avatar
Yeh lifting the throttle in an oversteer situation can be bad for RWD cars on the track.
[ame="https://www.youtube.com/watch?v=Hsbk3vBMMow"]Autobahn - South Course - Trailing Throttle Oversteer - YouTube[/ame]
My 2016 Build thread
The Following 2 Users Say Thank You to stevesnj For This Useful Post:
pushrod (02-09-2015), Ultramaroon (02-10-2015)
Where to Lift with Two Post Lift? Don Ivey Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 08-18-2022 08:51 AM
Part throttle faster than full throttle brn12345 Engine, Exhaust, Transmission 38 10-21-2021 12:20 PM
EZCarLift Easy car lift portable super easy car lift bren5279 Mechanical Maintenance and Tools 16 09-11-2015 01:57 PM
frs oversteer in brz mechanical? swpbrz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 03-18-2014 09:48 PM
