Old 12-29-2012, 10:21 AM   #1
Don Ivey
Drives: '13 FR-S
Where to Lift with Two Post Lift?
I am fortunate to have a two post in my garage, but not sure where best to lift the FR-S using the lift. any recommendations based on having done it? TIA,
Don Ivey
'13 FR-S (Hot Lava)
Don Ivey is offline   Reply With Quote
Old 12-29-2012, 10:40 AM   #2
bpracer
Drives: Asphalt FR-S
There is a place at each end of the pinch rail on the rocker panels used for the scissor jack. There are two little cuts in the pinch rail at each end and you are supposed to jack between the two cuts.
BTW, there is a provided floor jack mount point at the front of the car and you use the diff at the back.
Wish I had a lift...
Asphalt FR-S
1965 Mustang Vintage Road Racer
Ducati Paul Smart 1000LE
Ducati 848
bpracer is offline   Reply With Quote
Old 12-30-2012, 09:10 PM   #3
zooki
Drives: waiting on a 2021...
Yep, that's the spots I use to lift mine on my lift. I also bought 4 hockey lucks and split them. I use them to straddle the pinch weld so I'm not lifting by the edge if the sheet metal.
zooki is offline   Reply With Quote
Old 01-02-2013, 11:20 AM   #4
Books
Books's Avatar
Drives: Ultramarine FR-S (MT)
If you haven't found the pinch welds yet, here's a pic: (Taken from the DIY on jacking your car http://www.ft86club.com/forums/showthread.php?t=10111)
Books is offline   Reply With Quote
Old 08-18-2022, 08:51 AM   #5
e_lunatic
Drives: 2015 Scion FR-S
i also bough hockey pucks (didnt split mine though) after i actually made contact with the car on the arm of the lift and bent the underside bodywork right behind my passenger front wheel
highly recommend the pucks!
e_lunatic is offline   Reply With Quote
Turbo, Convertible, Face-Lift in 2016.. TOYSTRY BRZ First-Gen (2012+) — General Topics 14 04-02-2014 08:23 PM
EZ Car lift RRnold Other Vehicles & General Automotive Discussions 13 11-09-2012 04:20 PM
How to lift? Mo707 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 08-28-2012 12:57 PM
Home Car Lift SEC Other Vehicles & General Automotive Discussions 10 08-20-2012 10:17 AM
don't lift pr086 Scion FR-S / Toyota 86 GT86 General Forum 27 08-17-2012 11:51 AM
