Old 02-06-2015, 11:24 AM   #1
Jeff@Racer X Fab
Drives: Subaru BRZ, Toyota MR2 Turbo
Racer X Fabrication, new front LCA alum/chromoly
Well we have been toying with the idea for over a year now of offering a second option for our front lower control arms. We finally decided to make prototypes in October and we have been testing them on our shop car for the last 3 months. We are using an Aluminum main body camber arm, and a 4130 chromoly caster arm. These control arms have the same great features as the control arms we offer now, but now the camber and caster can be adjusted independently. This design allowed us to make the control arms with Anti-dive built in. The control arm also has 0.75” of roll center adjustment with the OEM ball joint.
The purpose of these control arms was to offer a middle ground between our full 4130 chromoly control arms, but better than OEM or OEM type replacements. We also wanted to reduce the cost and get it a little more affordable for those that have been thinking about it but just could not stomach the expense.
Here are a few pics, let us know what you think. We have made a few tweaks, and the production design is a little bit different but for the most part is the same as the prototype. We are always open to suggestions and what you guys are looking to see from our components!!
Just an FYI....we have heard your requests for multiple bolt holes on the Rear LCA, we will be getting them added on the next run.
Jeff@Racer X Fab is offline   Reply With Quote
The Following 9 Users Say Thank You to Jeff@Racer X Fab For This Useful Post:
Black Tire (02-06-2015), DAEMANO (02-11-2015), Decay107 (02-09-2015), DustinS (02-06-2015), FRSCanuck (02-20-2015), JDKane527 (02-09-2015), sunset_blvd (02-24-2015), Turdinator (02-09-2015), zoth (02-09-2015)
Old 02-06-2015, 11:49 AM   #2
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
kewl
Old 02-06-2015, 08:37 PM   #3
puma
crew chief
puma's Avatar
Drives: Race car FR-S
how is the weight of this one compared to the other one?
How different will the price be? Can it come with an adjustable ball joint like the other one?
puma is offline   Reply With Quote
Old 02-06-2015, 10:31 PM   #4
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
I certainly prefer the looks of these over the all-tube-constructed items. These appear more "solid".
This is from someone who knows nothing about loads and design.
Jeff@Racer X Fab (02-09-2015)
Old 02-06-2015, 10:36 PM   #5
puma
crew chief
puma's Avatar
i can tell you the other arms they build feel very solid when you have them in hand, in fact, i would have used something a little lighter and more flimsy so that it could bend in case of a side impact instead of destroying the support or the body of the car.
Old 02-07-2015, 04:22 PM   #6
wootwoot
Drives: FRS
It appears ppears these are the only option I have seen that can use factory style ball joints.... Or are my eyes deceiving me? And how do you adjust roll center with a stock ball joint?
wootwoot is offline   Reply With Quote
Old 02-09-2015, 12:04 PM   #7
Jeff@Racer X Fab
We are shooting for the price to be in the range of $529.00 to $579.00
Yes, these will have the option of using our RCA kit.
The current weight of the prototypes is: 5 lbs 2 oz. The arm itself, chromoly rod, and OEM ball joint weigh 2lbs 10 oz. The chromoly rod ends, hex adjuster, and nuts bring the weight up to 5lbs 2 oz. This is the sacrifice for making the arms adjustable on the vehicle.
Yes, these will work with the OEM ball joint or the ball joints offered by a few other companies. The RCA is changed by altering the seating position of the ball joint. In this case raising it.
The Following 2 Users Say Thank You to Jeff@Racer X Fab For This Useful Post:
DAEMANO (02-11-2015), wparsons (02-10-2015)
Old 02-09-2015, 07:06 PM   #8
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Subscribed for development updates
Decay107 is offline   Reply With Quote
Old 02-10-2015, 05:50 PM   #9
TekPrime
Chef
TekPrime's Avatar
Drives: 2014 Subaru BRZ Limited (D6X)
Is there any advantage to having the rod pivot on both ends rather than at a fixed angle in the full chomoly LCA's ?
TekPrime is offline   Reply With Quote
Old 02-11-2015, 09:20 AM   #10
Jeff@Racer X Fab
The main advantage to the two piece design is for camber/caster adjustment. With our full chromoly control arms these will have to be adjusted with respect to each other, changing camber will affect caster.
In short, getting an alignment will be more straight forward.
The Following 6 Users Say Thank You to Jeff@Racer X Fab For This Useful Post:
Black Tire (02-11-2015), DAEMANO (02-11-2015), Koa (02-11-2015), sunset_blvd (02-24-2015), TekPrime (02-11-2015), wparsons (02-11-2015)
Old 02-11-2015, 10:45 AM   #11
Koa
Looking awesome.
I don't regret buying the LCAs w/ new standard black anodized but only 1 strut hole mount.. quality for the $$ is the best, hands down
The Following 3 Users Say Thank You to Koa For This Useful Post:
DAEMANO (02-11-2015), Jeff@Racer X Fab (02-11-2015)
Old 02-20-2015, 10:17 AM   #12
Jeff@Racer X Fab
Final design for Aluminum front lower control arms!!
We finalized the design for the front lower control arms, here are a few screen shots of the final product. We will start cutting them next week, if there is enough interest we will offer a discounted price for the first batch.
Questions and comments always welcome.
Old 02-20-2015, 04:10 PM   #13
Captain Snooze
Drives: Red Herring
Could you please tell me what "PN:RX5-02041" refers to?
Why have you decided have only one mounting hole in the middle of the arm? Doesn't this mean you will have to make 2 different arms for left and right?
Old 02-20-2015, 05:27 PM   #14
JohnJuan
JohnJuan's Avatar
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
Doesn't PN usually stand for Part Number?
JohnJuan is offline   Reply With Quote
The Following 2 Users Say Thank You to JohnJuan For This Useful Post:
Jeff@Racer X Fab (02-21-2015), Shit Luck (02-24-2015)
Racer X Fabrication oil pan design and development! Jeff@Racer X Fab Engine, Exhaust, Transmission 87 06-03-2015 11:10 AM
DIY Changing Cam Plate Racer X fabrication Mr. DIY (Do-It-Yourself) Guides 0 08-06-2014 12:56 AM
Racer X Fabrication heat shield, help us to help you Jeff@Racer X Fab Engine, Exhaust, Transmission 31 07-17-2014 09:20 AM
Racer X Fabrication Suspension group buy: UCA, Rear LCA, Front LCA and more!! Jeff@Racer X Fab Groupbuys 74 06-23-2014 09:08 AM
Racer X Fabrication, New vendor intro Jeff@Racer X Fab Announcements, Contests, Giveaways 0 03-12-2013 11:50 AM
