| Northwest AK, ID, OR, WA |
Drives: innovate sc frs
cracked header
Gas fumes are great and all, but not in the cabin of the car.
I'm guessing I have two options: 1. Find someone to cut/weld. 2. Buy a new header. If you have experience welding, advice? (not welding it myself) Or what header? I've heard the tomei does well with my innovate and perrin set up. Thanks in advance! |
#2 | |
Drives: V8 280Z || AP2 S2K
Just the tip
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
I have the JDL UEL with my Innovate and I like it.
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
Drives: 2013 DGM BRZ
OEM header or what brand?
not playing cards
Where's it cracked?
edit: Pics or gtfo.
Geo Tyrebighter Esq
Drives: '13 scion fr-s
What happened?
Manufacturing, or sleeping policeman? Lacking vital information. 4/10.
"I gotta rock." -- Charley Brown |
not playing cards
Ok, Jonesy, I'll step in. Poorly manufactured. Jig was off making the weldment so, as mounted, the part highlighted in red hangs lower than it should. The flexible coupling bellows is stretched in an S-shape and subsequently cracked. This is an example picture with a similar header.
![]() We looked at it together and I initially suggested we cut out the cracked coupling and replace it with another. I would tack it in with the header mounted in place so it would conform to the rest of the shitty weldment without residual stress. I have an adequate TIG setup but am not the best welder in the world. I would get a nice bead but would also end up with a huge heat affected zone because I'm too slow. I don't use enough current because I'm always afraid of burning through the pipe. If I get it tacked, would anyone else volunteer to run a bead around it off of the car? Any input is welcome. Hare-brained scheme? Trying to save a few bucks. It's Jonesy's car so I didn't want to speak too much in his place.
not playing cards
what carbs do you have on your 260? Is it the original engine?
#10 | |
![]() Last edited by Yamaha_R6; 01-25-2015 at 06:20 PM. |
#11 |
Sending rods to their doo
Drives: 700HP STi
#12 |
Rolling start next time!By the way Jonesy, here are some pics of the header in case you're interested. ![]() ![]()
#13 |
Drives: 700HP STi
#14 |
not playing cards
Bump for feedback. Anyone care to recommend a good welder who can do stainless?
Jonesy, I hear that JDL is a respected unit. Lots of people running it.
| Cracked Screen on an OFT | Thrustin | Software Tuning | 3 | 08-03-2014 06:29 PM |
| Cracked Housing? | OURO3OROS | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 02-02-2014 07:43 AM |
| Cracked Oil Pan?! | Jolaessss | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 12 | 11-21-2013 02:28 PM |
| Has anyone cracked the OEM rotor yet? | ayau | Tracking / Autocross / HPDE / Drifting | 10 | 04-22-2013 04:41 PM |
| Cracked Rim | SmsAlSuwaidi | Issues | Warranty | Recalls / TSB | 29 | 04-02-2013 01:30 PM |
