Northwest AK, ID, OR, WA
Old 01-24-2015, 05:16 AM   #1
Jonesy86
Jonesy86's Avatar
Drives: innovate sc frs
cracked header
Gas fumes are great and all, but not in the cabin of the car.
I'm guessing I have two options:
1. Find someone to cut/weld.
2. Buy a new header.
If you have experience welding, advice? (not welding it myself)
Or what header? I've heard the tomei does well with my innovate and perrin set up.
Thanks in advance!
Jonesy86 is offline   Reply With Quote
Old 01-24-2015, 01:50 PM   #2
Yamaha_R6
Yamaha_R6's Avatar
Drives: V8 280Z || AP2 S2K
Thanks in advance!
I'm selling a JDL EL header if you're interested.
Yamaha_R6 is offline   Reply With Quote
Old 01-24-2015, 04:02 PM   #3
stockysnail
Just the tip
stockysnail's Avatar
I have the JDL UEL with my Innovate and I like it.
The Following User Says Thank You to stockysnail For This Useful Post:
Jonesy86 (01-25-2015)
Old 01-24-2015, 04:24 PM   #4
Akari
Drives: 2013 DGM BRZ
OEM header or what brand?
Akari is offline   Reply With Quote
Old 01-24-2015, 05:23 PM   #5
Where's it cracked?
edit: Pics or gtfo.
Old 01-24-2015, 10:32 PM   #6
Jonesy86
Jonesy86's Avatar
Xs power el.
Old 01-24-2015, 11:49 PM   #7
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
What happened?
Manufacturing, or sleeping policeman?
Lacking vital information. 4/10.
Old 01-25-2015, 12:23 AM   #8
Ok, Jonesy, I'll step in. Poorly manufactured. Jig was off making the weldment so, as mounted, the part highlighted in red hangs lower than it should. The flexible coupling bellows is stretched in an S-shape and subsequently cracked. This is an example picture with a similar header.
We looked at it together and I initially suggested we cut out the cracked coupling and replace it with another. I would tack it in with the header mounted in place so it would conform to the rest of the shitty weldment without residual stress.
I have an adequate TIG setup but am not the best welder in the world. I would get a nice bead but would also end up with a huge heat affected zone because I'm too slow. I don't use enough current because I'm always afraid of burning through the pipe.
If I get it tacked, would anyone else volunteer to run a bead around it off of the car?
Any input is welcome. Hare-brained scheme? Trying to save a few bucks. It's Jonesy's car so I didn't want to speak too much in his place.
Old 01-25-2015, 04:29 PM   #9
what carbs do you have on your 260? Is it the original engine?
Old 01-25-2015, 06:10 PM   #10
Yamaha_R6
Yamaha_R6's Avatar
I have the L26, however the carbs are early 240 style. Someone is planting seeds in my head about swapping in a VQ later on
Old 01-25-2015, 06:12 PM   #11
Touge_ninja
Sending rods to their doo
Touge_ninja's Avatar
Drives: 700HP STi
I have the L26, however the carbs are early 240 style. "Someone" is planting seeds in my head about swapping in a VQ later on
Bro RB26 just cause you got smacked that one night jkjk
Touge_ninja is offline   Reply With Quote
The Following User Says Thank You to Touge_ninja For This Useful Post:
Yamaha_R6 (01-25-2015)
Old 01-25-2015, 06:17 PM   #12
Yamaha_R6
Yamaha_R6's Avatar
Rolling start next time!
By the way Jonesy, here are some pics of the header in case you're interested.
Old 01-25-2015, 06:42 PM   #13
Touge_ninja
Drives: 700HP STi
Real men race from a dig JKJK
Old 01-26-2015, 01:57 PM   #14
Bump for feedback. Anyone care to recommend a good welder who can do stainless?
Jonesy, I hear that JDL is a respected unit. Lots of people running it.
Yamaha_R6 (01-26-2015)
Cracked Screen on an OFT Thrustin Software Tuning 3 08-03-2014 06:29 PM
Cracked Housing? OURO3OROS Cosmetic Modification (Interior/Exterior/Lighting) 7 02-02-2014 07:43 AM
Cracked Oil Pan?! Jolaessss Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 12 11-21-2013 02:28 PM
Has anyone cracked the OEM rotor yet? ayau Tracking / Autocross / HPDE / Drifting 10 04-22-2013 04:41 PM
Cracked Rim SmsAlSuwaidi Issues | Warranty | Recalls / TSB 29 04-02-2013 01:30 PM
