Old 01-21-2015, 05:37 PM   #1
BRZUK
Drives: GT86
Gauges for supercharger
Hi Guys,
I am putting a supercharger on the car and want to keep gauges to a minimum, I have decided to go with AFR and Boost Possibly Oil Temp.
What of the 2 following would you recommend ?
http://www.ft86speedfactory.com/aem-...-afr-1585.html
http://www.ft86speedfactory.com/inno...play-1809.html
Thanks Guys
BRZUK is offline   Reply With Quote
Old 01-21-2015, 05:42 PM   #2
Koa
the inno, hands down
Old 01-21-2015, 05:59 PM   #3
BRZUK
Drives: GT86
What makes you say that tho ?
Old 01-21-2015, 06:39 PM   #4
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
p3 vent pod gauge @ mod bargins. 10 gauges in one, sits in the driver side a/c vent (and allows the ac to pass through.)
The Following 2 Users Say Thank You to Kiske For This Useful Post:
continuecrushing (01-22-2015), Dream20b (01-22-2015)
Old 01-21-2015, 06:41 PM   #5
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
Android HU and
http://www.ft86speedfactory.com/hks-ob-link-302.html
-Jack Burton
Old 01-21-2015, 06:46 PM   #6
BRZUK
Drives: GT86
Originally Posted by tahdizzle View Post
I prefer data coming from a hard wired sensor straight to gauge rather than the car processing the information then transferring it to readable data to the OBD then to the bluetooth
The Following User Says Thank You to BRZUK For This Useful Post:
Old 01-21-2015, 06:47 PM   #7
tahdizzle
So elite I'm 1338
to each their own
-Jack Burton
The Following User Says Thank You to tahdizzle For This Useful Post:
BRZUK (01-21-2015)
Old 01-21-2015, 06:48 PM   #8
BRZUK
Drives: GT86
I assumed with the P3 Gauge you could only display one peace of information at any time, is this correct?
Old 01-21-2015, 07:13 PM   #9
Whatabouteggs
[Citation Needed]
Drives: 2014 WR Blue Subaru BRZ Premium
This.
Whatabouteggs is offline   Reply With Quote
Old 01-21-2015, 08:17 PM   #10
Cards2323
Drives: 2014 BRZ Limited-SWP
I had the innovate in my other Subaru so Im bias but thats what I would go with
Cards2323 is offline   Reply With Quote
Old 01-21-2015, 09:32 PM   #11
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Yes, there is a button on the front of the gauge allowing you to easily toggle whenever you want though.
Old 01-21-2015, 10:40 PM   #12
Calum
That Guy
Drives: 2013 asphalt FRS MT
I'm with you on the android HU, but jesus that HKS is over priced.
how about one of these
http://www.aliexpress.com/item/YD182...856749046.html
or one of these
[ame="http://www.amazon.com/ELM327-Version-Bluetooth-Diagnostic-Windows/dp/B00QUL6U8Y/ref=sr_1_1?s=electronics&ie=UTF8&qid=1421897896&sr =1-1&keywords=obd2+bluetooth+adapter"]Amazon.com : ELM327 Latest Version V2.1 Bluetooth Super Mini ELM327 OBD2 II Scan Tool Car Auto Diagnostic Tool for Windows (blue) : Electronics[/ame]
Old 01-21-2015, 10:54 PM   #13
Whatabouteggs
[Citation Needed]
Originally Posted by Calum View Post
No, no no. If you want any usable real-time info, you need to not cheap out on the OBD2 reader. The website for the torque app lists some good ones. The problem with the cheapos is that they have a very low sample rate. If all you want is to read/erase codes or make sure your idle temps/pressures/trim is within a certain range, then one of those is fine. But if you want to use it for gauges, or do some data logging for your tune, you need to have something a little more substantial.
The Following User Says Thank You to Whatabouteggs For This Useful Post:
Calum (01-22-2015)
Old 01-22-2015, 10:50 AM   #14
Xuningshen
Drives: Subaru BRZ
for me, its AEM failsafe for AFR and boost,
[ame="http://www.amazon.com/AEM-30-4900-Wideband-Failsafe-Gauge/dp/B007ZAQLF6/ref=sr_1_1?s=automotive&ie=UTF8&qid=1421941793&sr= 1-1&keywords=aem+failsafe"]Amazon.com: AEM 30-4900 Wideband Failsafe Gauge: Automotive[/ame]
then the innovate oil press/temp
[ame="http://www.amazon.com/Innovate-Motorsports-3852-Function-Temperature/dp/B0081WP9CS"]Amazon.com: Innovate Motorsports 3852 MTX Digital Series Dual Function Oil Pressure and Temperature Gauge Kit: Automotive[/ame]
2014 WRB BRZ
Xuningshen is offline   Reply With Quote
Gauges for frs? wootwoot Cosmetic Modification (Interior/Exterior/Lighting) 9 02-26-2015 01:19 PM
Necessary gauges misooscar Engine, Exhaust, Transmission 5 09-18-2014 02:42 AM
Gauges for supercharger? LtS720 Forced Induction 15 12-23-2013 09:14 PM
WTB: Gauges AtlasMick Engine, Exhaust, Bolt-Ons 2 03-29-2013 12:04 AM
Gauges CyberFormula Scion FR-S / Toyota 86 GT86 General Forum 45 07-24-2010 06:26 PM
