Old 09-17-2014, 08:52 PM   #1
misooscar
misooscar's Avatar
Drives:
Necessary gauges
Hello,
I'm running a 9psi Vortech setup on my frs, with the OFT interface.
Planning to track soon.
What gauges do you recommend for oil temperature, oil pressure, boost gauge, and coolant temp.
Brand and vendor recs would be appreciated.
Also, am I missing any essential gauges?
Also, what is the best way to log this data?
Thank you!
misooscar is offline   Reply With Quote
Old 09-17-2014, 09:47 PM   #2
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Mods move to forced induction
The AEM truboost gauge gives AFR (vital) and boost (vital)
There's the innovate MTX gauge that does oil temp &/or pressure I can't remember.
Then the coolant gauge (can't remember who makes that one)
Old 09-17-2014, 11:17 PM   #3
steve99
Originally Posted by misooscar View Post
Hello,
Thank you!
you can use the OFt to display any 3 of the monitored parameters in a "big guage" format.
The OFT will also support an AEM wide-band input on the second o2 sensor with appropriate AEM sensor/controller and wiring harness, just select log parameter "Wideband AFR"
OFT will log up to 12 data channels of the 30 available log parameters
see OFT TIPS thread link below.
[ame="http://www.youtube.com/watch?feature=player_embedded&v=oBVFMBbpjv8"]OFT Digital Gauge and Wideband AFR support - YouTube[/ame]
[ame="http://www.youtube.com/watch?feature=player_embedded&v=Aar9SyK3Uwc"]OFT Multi-gauge function - YouTube[/ame]
Old 09-18-2014, 12:06 AM   #4
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
In order of importance (my two cents): AFR, Oil Pressure, Oil Temp, Boost, Water Temp (which is already on your dash). AEM Wideband Failsafe can display both boost and AFR in one gauge.
rb6freak is offline   Reply With Quote
Old 09-18-2014, 02:13 AM   #5
RedLeader
RedLeader's Avatar
Drives: 2013 Firestorm FR-S
If you really think you're actually gonna be looking at the gauges while you're going around the track, you really should only need coolant and oil temp. Boost and AFR will change too fast for you to keep track of other than on a long straight, otherwise you should be looking at the track. Coolant and oil temp generally creep up and you'll be able to quick check them to see if they are getting out of hand so you can take it easy and get off the track.
But since no one here listens, go ahead and get one of every gauge, that way you can say "racecar" and not actually know what half of the information actually means other than "shit's broke"
Old 09-18-2014, 02:42 AM   #6
Kodename47
Kodename47's Avatar
Drives: UK GT86
Do you really need boost and a wideband on a S/C car? Its not like a turbo where boost can change and therefore the AFRs should be fine too if tuned well. TBH the AFR on the stock O2 will be good enough for ballpark figures to know if its too lean.
.: Stealth 86 :.
Kodename 47 DJ:
TRD Sports Gauges Tech DIY (Do-It-Yourself) Guides 59 02-14-2022 01:04 PM
Gauges Lunatic DIY (Do-It-Yourself) Guides 14 07-04-2014 02:59 PM
WTB: Gauges AtlasMick Engine, Exhaust, Bolt-Ons 2 03-29-2013 12:04 AM
gauges where the radio is? J-Money Cosmetic Modification (Interior/Exterior/Lighting) 7 02-05-2013 10:11 PM
Gauges CyberFormula Scion FR-S / Toyota 86 GT86 General Forum 45 07-24-2010 06:26 PM
