Drives: 2013 BRZ limited WRB
Water dripping under car
So I installed an AVO base turbo kit last month. Never noticed before(never cared to look though) but when I park water drips down off the engine somewhere around the transmission area. I haven't been running the AC so I wouldn't think its ac condensation. Any ideas what this is? Thanks
92 240sx (sold), 03 350z (sold), 13 BRZ (AVO turbo)
#2 | |
Drives: 2013 Asphalt FR-S
~Namaste~ |
#3 | |
Engineering Student
Drives: Scion FR-S 2015
That's it? How would you explain an exhaust leak (curious)...
There’s no time to stop for gas, we’re already late
[Citation Needed]
Drives: 2014 WR Blue Subaru BRZ Premium
Water condenses in the exhaust from the combustion process (water is a byproduct of combustion), as well as water vapor entering from the ambient air due to temperature and pressure changes, etc. In a boxer engine the exhaust manifolds are a low point, as opposed to normal engines where the manifolds are higher than most of the exhaust system. Therefore even in a stock car, water is bound to gather in some quantity in the manifolds. If the manifold gaskets aren't sealing properly, this can leak out.
That Guy
Drives: 2013 asphalt FRS MT
It could also be the ac. If you're running with the heat on and the vents to defrost the car will cycle the ac to remove moisture from the incoming air.
#6 | |
Engineering Student
That is very well written and explained. Thank you
#7 | |
I Love custom Turbo kits
Drives: Limited BRZ
| Weird sounds and liquid dripping from car | kam | Issues | Warranty | Recalls / TSB | 21 | 05-07-2014 07:01 PM |
| water temp | driver01 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 30 | 04-11-2013 02:57 AM |
| Water in trunk | Spencer | BRZ First-Gen (2012+) — General Topics | 14 | 03-15-2013 10:17 PM |
| ROCKET BUNNY FR-S VIDEO DRIPPING WITH STYYYYLE :D | switchlanez | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 9 | 10-12-2012 12:13 AM |
