Old 01-13-2015, 05:35 AM   #1
Brofessor
Drives: 2015 Halo FR-S
FR-S LED DRL to Foglight Conversion
So I have an FR-S that came with the dealer option of those horizontal LED strip DRL's in the turn signal/bezel area. I have ordered a Diode Dynamics fog light kit, and I want to bounce some ideas off anyone who cares to chime in.
My plan is to, instead of splicing the fog light signal (on/off) wires to the headlights as they suggest (which would mean my fogs would be on anytime the headlights are on - don't want), I will splice my fog light wires to the DRL wires of the old LEDs, and just tape off the actual plugs.
My thought is that since there is an independent switch to turn the LED DRL's on and off, regardless of e-brake/headlight/etc., the fog lights should then be controlled by that switch instead once they are installed in place of the LEDs.
So tell me - is my logic flawed, or will this theoretically work ok? I'm no electrician, so I'm going based off my limited understanding of such issues. If anyone has thoughts on it, I'd appreciate any advice.
Brofessor is offline   Reply With Quote
DIY Rear foglight Silverdub DIY (Do-It-Yourself) Guides 159 04-09-2018 12:14 PM
A better BRZ foglight option! Opie Cosmetic Modification (Interior/Exterior/Lighting) 128 08-18-2014 09:29 PM
H11 LED Foglight FRSure Cosmetic Modification (Interior/Exterior/Lighting) 10 03-07-2014 11:37 AM
FS: oem foglight stalk GT86drifter Exterior Parts (Aero, Lighting, Etc.) 3 05-15-2013 09:38 AM
Foglight replacement help Zadkiel Cosmetic Modification (Interior/Exterior/Lighting) 4 08-06-2012 11:11 AM
